Toshiba 27AF41 27" TV
Problem for Toshiba 27AF41 27" TV
Help/Advice on Toshiba 27AF41 Television!
By Lizzy - usenet poster
I have recently purchased this unit & I am in need of help from anyone who
is in the know about this set.I am noticing a slight inward bend on the top
left & right of the picture when running various test patterns (I am running
the patterns from a source dvd) & when watching any films/tv shows.
Is there anything I can do to correct this problem? I have attempted to
correct the problem by lowering the contrast,adjusting sharpness,etc..The
manual that the television came with as well as the on screen menus have
been no help.
I would appreciate any help/feedback any one can give me.Please respond
privately as I am unable to check newsgroups often.
Thanks,
Kenny
Solution #1
posted on Aug 07, 2005
Not Rated)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
It sounds like your set may be exhibiting some pincushion distortion at the
top of the screen. Most TVs have service menus that allow a much broader set
of adjustments than what is available from the standard user menu. You can
probably fix this from the Toshiba service menu, but making service menu
adjustments is something that should be attempted only if you are careful.
Go to
http://www.members.accessus.ne t/~090/awh/how2adj.html
for some very good info on this sort of thing. The site also has info on how
to get into the Toshiba service menu. BUT MAKE SURE YOU WRITE DOWN THE
DEFAULT VALUES FOR ANY CODES BEFORE YOU MAKE ANY CHANGES!
Was this helpful?
Yes
No
Solution #2
Not Rated)
Hart
Rank: Apprentice
Rating: 0%, 0 votes
All these sets have slight pin errors of some type.  You can call the
manufacture rep for a warrenty call, but I have a feeling that your set
is most likely within their specs.
These sets have a spec of about 2% pin error to the edge of the screen.
This means that on a 27 inch diagnal tube, the error can be about  0.54
inches.  This is +- 0.27 inches average.
The more expensive models, may be a bit more accurate but not by much.
The price may increase by a lot in order to get a bit more performance
accuracy.  The only very accurate sets are a true TV monitor.  This
would be very expensive to purchase for viewing home TV.
Greetings,
Jerry Greenberg        GLG Technologies GLG===========================­===================
WebPage         http://www.zoom-one.com
Electronics        http://www.zoom-one.com/electr on.htm
Instruments       http://www.zoom-one.com/glgtec h.htm
who
top
running
sharpness,etc..The
been no help.
Thanks,
Kenny
Was this helpful?
Yes
No
Popular Solutions for Toshiba 27AF41 27" TV
Questions and Unsolved Problems for Toshiba 27AF41 27" TV
Do you recommend Toshiba 27AF41 27" TV?
Answer
Answer
Tv was givin to me with no power button and a remote, I told giver that I I have comcast remote.... (More)
Answer
My television keeps having a flashing red light when I try to tun it on. Is there anyway to turn it... (More)
Answer
The tv won't turn on when I press the poswer button. The red light blinks, but won't turn off when I... (More)
Answer
The tv won't turn on when I press the power button. The red light blinks, but won't turn off when I... (More)
Answer
cant gat my older rca direct tv remote to operate my toshiba model 27af41 tv
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
