Question about Indesit Dishwashers
Dishwasher needs on button pushing many times before it will start
    Sergeant:
  • 351 Answers
Dont know what brand you have but the button needs replacing
Posted on Aug 27, 2008
The dishwasher is displaying 5H in the time panel is there any way that could happen by pushing the wrong button and is there any way to make it go away
It would help to know the model number to determine the features of your dishwasher. The only guess I can make is that someone pushed the "delay" button and you are now set for a 5 hour delay for starting the dishwasher. Pressing the Delay button a few more times should bring it back to Zero delay.
Feb 28, 2015 | GE Dishwashers
Cannot push the start button of my wirlpool dishwasher (WDT710PAYM3)
If you can get to the motor, unfortunately, you may have to pull the dishwasher out to get to it unless you can access it from the adjoining cabinet. The motor may have a red button on the back of it which is the "Reset" button. Press it in and if it clicks, you have reset the motor. I hope this helps, good luck.
Oct 22, 2014 | Dishwashers
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Dishwasher has power but when i push the start button, nothing happens. Will not start and the unit has never had this problem before.
    On a electronic board. There is usually a way to lock on it. Most of the time it is by pushing down on two buttons. If you have your owners manually it should tell if which buttons they are.
    May 13, 2011 | Dishwashers
    I am gettting a message on my dishwasher that says 1h
    I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
    Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
    Cancel light and rinse only light keep blinking and wont start
    Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
    Open dishwasher door,
    Push Hi Temp Scrub button,
    Push Saver Dry button,
    Push Hi Temp Scrub button again,
    Push Saver Dry button again,
    All lights on control panel will come on.
    Close dishwasher door,
    Push Baked on Cookware or Normal Button.
    Dishwasher should start and complete cycle.
    It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
    Good Luck,
    Tom
    Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
    Kenmore Quiet Guard Dishwasher only starts when pressing start repeatidly
    No personal experience with this machine, but two things come immediately to mind:
    1. If the door latch is not quite closed then the machine still thinks it is open and thus will not start. Try gently pushing on the door as you push the start button. If no joy, then check to make sure that the latch mechanism (what can be seen of it - usually very little!) has no food deposits on it.
    2. The start button contacts may be corroded. Try pushing the start button more firmly - and wiggle it at the same time.
    Jul 16, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
    Whirlpool dishwasher # quiet partner II
    Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
    Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    The "Rinse Only Button" will not function even after going through the "Cancel" cycle.
    br, sounds like you have a stuck keypad. This would be the only reason it is switching to a different cycle. Catriver..post back.
    Oct 01, 2006 | KitchenAid 24 in. KUDS25 Built-in...
    Dishwashers Logo
    48 people viewed this question
    Top Indesit Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Eric Taylor
    Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
