Question about Dell PV124T LTO3 16 SLOT COMES WITH 1 MAG Tape Drive
USE OF DELL PV124T LTO3 TAPE DRIVE USING AND LTO2 TAPE USING WINDOWS BACKUP FEATURE IFY usua_ie@yahoo.com
  • rlofgren Nov 06, 2008
    Same Dell tape unit using Symantec for backup. Tape is stuck back in the reader part of the tape unit
  • Anonymous Apr 01, 2009
    Same error with PV132T LTO2 drive. Shows Error 6 and tape is stuck in drive. Will not eject.
I have DEll PVT110t LTO2 backup drive & my backup tape got stuck into it.please help me for the successful ejection of tape.
Posted on Oct 18, 2008
IBM 3580 Lto3 drive showing in Device manager but not showing in ntbackup while taking bkp
I am guessing you don,t have a driver installed for this device.
Just manually add the driver but look for LTO as the MANUFACTURER - there is a generic driver in there which should work fine.
Better still, also upgrade your backup program - even to an old copy of backup exec. It has proper cataloguing and also its own driver family too.
http://tape-drive-repair.com can help with this if you are in the UK
Sep 06, 2013 | IBM TotalStorage 3580 L33 (3580L33)...
Failing to recognize tapes in Sun StorageTek C2 tape library
Are you seeing a cleaning light or is it just ejecting the tapes? If it is ejecting them then make sure to try a brand new tape of the right type (if it is the wrong tape type it will eject).
Also try a cleaning tape if the cleaning light is on.
If that does not work then you will need to send in the tape drive somewhere for repair as the head might be worn out or the drive needs a good service.
Try going to http://tape-drive-repair.com who sell and repair these units. The LTO2 and LTO3 drives are pretty inexpensive now and so this should be fairly cheap to have sorted.
Also this unit is the same as the Quantum superloader3 so that might help if you are still googling for a solution
Sep 05, 2013 | Computers & Internet
LTO tape Drive keeps ejecting tape
This could be that you are putting an LTO3 or LTO4 tape in the drive (or expired cleaning tape) Or it could be that the tape or tape drive has a problem reading the data.
Try using a brand new cleaning tape (clears the cleaning issue) and then try a brand new LTO2 tape.
If this works, then the issue was just related to your tapes, if this does not work then there must be a problem with he drive itself.
If the problem is with the drive, then contact www.tape-drive-repair.com for replacement costs. These drives are now very inexpensive and it might just be easier to replace the drive.
If you want to attempt to fix the issue yourself then respond back with a few more details and i will try and advise you on the best things to try.
Sep 07, 2012 | Dell PowerVault 110T LTO-2 Ultrium Tape...
Tape cartridge seems stuck in the my tandberg LTO2 HH external drive.how to remove it?
I had the same issue with my drive. I presume that you have tried holding down the eject button while powering on the drive. If you have done this and it didn't work, I have a PDF from Dell that describes how to manually remove a stuck tape from this drive. I would not recommend it for anyone who is not very technical. It is a little complicated. If you would like a copy of it, you can send me an email at my hotmail.com email. It is tm_reply at hotmail.com. Since the PDF does not have the directions to re-assemble the drive, you need to pay close attention to the way things are while taking it apart.
If you are not comfortable sending me an email, you can go to Dell's support an do an online chat. Ask them for the doc. That is where I got it. He emailed it to me so that is why I don't have a link.
I do have a link for the full height drive. it is - http://support.dell.com/support/edocs/stor-sys/110TL_Ce/en/index.htm
Thanks
Todd
P.S. If someone can tell me how to post a file here, I would be happy to do so.
Oct 21, 2009 | Tandberg Data 200/400GB 420LTO LTO2...
No Compatible media found in HP Tape Drive
Try a brand new tape fresh out the wrapper.
If that doesnt work make sure you are using the right drive in your backup software!
It sounds like a message often seen in windows backup where you have selected the wrong tape drive from the list and it just tells you "No compatible media found" when actually the drive listed isnt even connected to your system still
Nov 27, 2008 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Nov 13, 2008 | Quantum SuperLoader 3 LTO 2 Tape Drive
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
ATL Superloader with LTO2 drive
The LTO family drives all support a tape-related diagnostic spec called TapeAlert, and if you use a software product that decodes it and can dump out all of the settings related to firmware, error logs, etc ... then I have no doubt it will provide root cause. Check out http://www.santools.com/smart/unix/manual (the code is also ported to windows. There are links for TapeAlert reporting) Or go to http://www.tapealert.org for info on the spec.
Feb 08, 2008 | Quantum ATL SuperLoader Ultrium Tape Drive
Dell PV124T LTO3 16 SLOT COMES WITH 1 MAG Tape Drive Logo
832 people viewed this question
Alun Cox
