Question about Casio Cassiopeia E-100 Pocket PC
I can't perform Active-Sync with my Serial Cable to Casio E-100!?
Help Someone, I was able to Sync my Casio E-100 to my PC recently, but now I can't. I deleted a bunch of stuff of the Casio including communication, but on the device it still says trying to connect. I've uninstalled active sync and re installed it and rebooted my Casio e-100. What should I do?
    Master:
  • 551 Answers
You might try this.... Assuming that you deleted a file you shouldn't have, perform a hard reset on the Casio. You know the type, the type that will erase everything from memory and reset the device to like new. I think you hold down the power button while pushing the reset or something like that if I remember correctly. If you've already reinstalled activesync, they you would be all set.
Posted on Sep 06, 2005
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
IPAQ H5500 USB CONNECTION TO PC NOT WORKING
open active sync on ipaq and connect the cable with pc and ipaq. if not recognised perform a soft reset on ipaq. also check in  active  sync on pc >file> connection settings> allow usb connections is checked
Jul 20, 2007 | HP iPAQ H5555 Pocket PC
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Problems with installing Active Sync on Windows xp.
Do you use companion CD for Active sync installation? Can you please tell me which driver is necessary to have? Is there any error message and what is content of this message? It can also be that Active Sync is already installed! Please check at Add and remove Software in Control panel! Otherwise go to www.microsoft.com and download a current version of active sync
Sep 11, 2005 | Toshiba e400 Pocket PC
E -100 Help
Casio had a cable that had a serial port on one side and a connector to the E-1XX on the other side. Activesync works through this: I searched on Casio E-100 sync cable serial in Yahoo. It found two hits for a cable under $40. That should allow you to install programs over your serial port. I have persoanlly only used Etronics form the list of two and they did what they said they would do. "Casio Cassiopeia E-Series Serial Cable Mfg Part No: JK580CA UPC Code: 079767693206 Product listed below is: Sort this table by: New from U.S. Distributor Vendor Rating SORT BY: PRICE | VENDOR RATING VENDOR SOURCE IN STOCK SHIPPING COST PRICE VENDOR RATING TheNerds.net DIRECT LINK Direct from Vendor 04/02/04 Yes See Site $31.86 4.5 out of 5 stars Etronics DIRECT LINK Direct from Vendor 04/01/04 Yes $9.14 $38.35 5 out of 5 stars "
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Cassiopia EM500 sync issue
First of all ensure that the port selected on the EM-500 for PC connection is the same as your actusl connection - i.e. USB or serial. There were some problems with the EM-500 cradle which would not allow communication to be established between the PDA & the PC/Laptop. Contact Casio for rectification. It is done free of charge.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
BE300 and PC Connect
If you have active sync installed it will stop pc sync from operating properly. If you don't have active sync on your system then go to the below forum and do a search for info on syncing. There are issues with pc sync that have been remedied with some updates.
Sep 06, 2005 | Casio Cassiopeia BE-300 Pocket PC
Activesync Problem, Help Pls
Try the following. FIRST & FOREMOST BACKUP YOUR DEVICE TO A "CF CARD" USING THE BUILT IN "CardBackup" UTILITY. This is a much faster option than using ActiveSynch. It ca restore also much faster. Once your files have synched go to options & change the synch options to manual & file conversions to NONE. Remove or switch off the device. Next delete the partnership WITHOUT DELETING THE SYNCH FOLDER !!! Be very careful. Switch on or replace the device on the cradle. Active synch should recognise the device & offer to setup the partnership. Let it do so with "THIS COMPUTER ONLY" option. Once your device is scanned by activesynch one of the options it will offer is of combining the records. Select it & let it synch. I most cases this should solve the problem. Hope this helps.
E-100 Serial Connection Question
Go to your device manager in your laptop/desktop, then click on modems, then click on communications cable between two computers, then click on the modem tab and change the speed to 115200, then reboot (it doesn't say you have to but you need to). Change the speed in the casio communications to 115k and then sync. Reply With Quote
Sep 05, 2005 | Casio Cassiopeia E-100 Pocket PC
EM-500 sync problem
There have been issues with the cradle PCB on the EM-500. Casio has redesigned the same added an IC & a few additional componentes. I had similar problems & simply could not connect through the USB port. Worked flawlessly with the accessory serial cable (direct connection - no cradle ). This also was on an XP system. See if you can wangle out a free replacement/fix for yout cradle from Casio.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio Cassiopeia E-100 Pocket PC Logo
138 people viewed this question
Top Casio Computers & Internet Experts
k24674
Computer Links
TimK
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
