Monitor emachine can`t seem to adjust horz width hope you can help me.don`t have service manual for this model(786n) eview17f3
  • Manolito Lao
    Manolito Lao Jan 21, 2009
  • 5,568 Answers
If the width is shrinking, check also if the edges are now distorted too.
If so, there is a 'bipolar' capacitor in the high voltage section that is failing.
To find and verify this, you will need a meter that can measure capacitance, and perferably, DF or losses of capacitors as well.
If you ignore this, the horizontal will continue to shrink until the deflection stops completely and can cause other, more costly parts to fail although these may also be weakened and failing.
I'm afraid this is not a DIY problem.
Posted on Aug 27, 2008
Want to adjust brightness and contrast on monitor
First you need to know the Make and Model of the Monitor. Second, go back to store where you bought the Monitor and aske for a Manual. Third, when you learn about the Make and Model of the Monitor, search Google for an Instruction Manual to it. Any of these suggestions would help you!
Oct 23, 2017 | ACER INCORPORATED eMachines eMachine...
Where is usb port on model 786n mag innovision desktop
The MAG Innovision 786N is a CRT monitor. It will not have a USB port. Look on the computer for a flat input, approximately 1/2 inch wide x 1/8 inch tall. There are likely two or more together, those are your USB ports. Unless your computer is more than 10 years old...
Dec 25, 2013 | Computers & Internet
I have a old CRT Proview monitor. It has developed a problem of exceeding display sidways, means the display from left and right side of screen goes beyond, I have adjust manually left and right to view...
Well, if the adjustment buttons don't work, then probably the control unit in the monitor is broken, or a key is stuck. If the control unit needs servicing, I doubt if it's feasible to have it repaired, given the fact that it's an old monitor and new or used nice slim LCD monitors can be purchased cheaply nowadays.
Jul 24, 2011 | Proview Computers & Internet
I am not able to expand the screen
Did you try to adjust with front pannel switch?
If the switch not working then change the micro switches.
Check the width boost capacitor (Polyster cap. 1.5Kv / 1.8kv / 2kv etc) in Horz. section
Check the SMPS voltage for Horz.
May 02, 2011 | LG Flatron F700P 17" CRT Monitor
Emachine 786n mointor frozen emachine logo
Try a different monitor. Most likely your having operating system issues that cause the monitor to do this.
Also - try this - As you turn the machine on tap the DELETE key - this will take you to the DOS platform of the computer. If the screen changes to anything you have operating system issues. Try a repair with the original disk or the operating system disk that was last installed.
May 08, 2010 | Computers & Internet
Dynex 19 inch tv used as pc monitor; the pc display is bigger that the width of the viewable screen which cuts off about 1/4 inch on each side making it difficult on some things to shut down since the...
Above is a manual link. usually you use multiple presses on the buttons to get to the menus. One button, is menu, the others are for up.down & left/Right. The same as for Horz Posn. You press the menu, use the L/R buttons to go to the menu item, then up and down to + or - the setting.
have a look at the manual.
Apr 23, 2010 | Televison & Video
How do you adjust the height and width of the screen?
there will be buttons on the screen monitor....front/side/back
one for the function and others for increase / decrease...etc...
u r the best judge how to do the monitor is with u...ur machine has to be on and the monitor should be getting signal and in working mode...for u to adjust
Dec 22, 2009 | E-Machines eMachines Monitor E15T4
Ibm E54 monitor width problem
1.To replace TIP122 and it's related transisters (A733,C945) tracing TIP122 pins
2.Change Flyback caps
3.Open OSD select ZOOM Option and press 20 sec OPEN SERVICE MODE decrease the Width option &save it
4.Switch off the monitor
IF these solution was usefull pl appreciates rating
Nov 19, 2008 | IBM E54 15" CRT Monitor
Computers & Internet Logo
552 people viewed this question
David Payne
David Payne
