Question about Intel Motherboard
Where you can find a file for a BIOS?
I've got an ASUS EZ FLASH v.1.00 2002 BIOS version: ASUS P4S800
and I tried to update my bios, but this order locks me the computer. And now I need a file for restart the computer. And I don't now where I can find.
PD
I haven't got internet in my computer.
my e-mail is: velacons@hotmail.com
thanks.
  • Roberta Smith
    Roberta Smith May 11, 2010
    did you flash with the wrong bios ?
    Robert
I need a file of BIOS to put it in the A: device.
But I don't know how I can get it.
Posted on Aug 28, 2008
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
1005ha bios update usb
Upgrading BIOS is dangerous and can cause fatal damage to your PC. If you are aware of that and decide to take this risk, then continute. 1. Visit http://support.asus.com/download/download.aspx?SLanguage=en-us, search 1001HA and choose DOS as operating system. Download latest bios rom file.
2. Save and extract the downloaded file. You will get a rom file named like "1301.rom" 3. Format a usb pen drive to FAT-16 partition. In my case I used a 32 MB SD card which came with my old Kodak camera, and I used a SD card reader that PC can see it as a usb disk. Copy 1301.rom to its root folder and rename it to 1005HA.ROM. The reason for renaming it to 1005HA.ROM is that EZ Flash on this 1001HA netbook looks up rom with this name. If EZ flash failed saying trying to find a rom file with another name, just shutdown the netbook and rename your rom file to the required name and try again. 4. Plug in the usb pen drive and reboot the netbook. Make sure that during the ASUS splash screen, press ALT+F2. Then EZ Flash will run automatically and try to locate the usb drive and read from file 1005HA.ROM (in my case). 5. It takes around one minute for me to upgrade everything. DO NOT TURN OFF OR EVEN TOUCH YOUR NETBOOK DURING UPGRADE. Read the messages on the screen and when it says you can press the shutdown button, you can turn off your system. 6. Turn on your netbook again and enter BIOS to check if the BIOS version is up to date.
http://www.youtube.com/watch?v=61awfpVe49k&feature=player_detailpage
Jun 11, 2012 | ASUS Eee PC 1005HA Atom N270 TFT Notebook
How to upgrade the BIOS on Asus P5RD1-VM Mother Board
first download the the update from here:
USB and flash it off that from within the BIOS using ezflash
put the bios update in a USB flash moemory and flash it off that from within the BIOS using "Asus EZ flash" technology.
but please don't forget vote.
Jan 13, 2011 | ASUS Computers & Internet
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Bios asus P5S800VM,rom
Try Updating your System Bios from
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5S800-VM
Version 1023
Update Procedure:-
1. Copy the ROM file in a pen drive
2.connect the Pen drive to the usb port of your Motherboard
3. Restart your m/c and press Del Key and Enter Setup
4. Go to
ASUS EZ Flash and update the Bios.
Jun 06, 2010 | ASUS P5S800-VM Motherboard
Problem with my Asus p5pe-vm motherbord.When i start it,the message CPU uCode loading error appears.What to do...HELPPPPPPP
If your over clocking your CPU settings reset to default. See if you still get the error. If you still get the error than update your bios. There are a couple of way to do this. You can use the software on your Asus CD or you can down load the latest BIOS-Utilities, Afudos BIOS update tool V2.36. Than download the bios file, P5PE-VM BIOS 1501.
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=download
Using built-in EZ Flash to flash BIOS Please be informed that not all motherboards support EZ Flash,
please use DOS flash utility to update BIOS if your motherboard does not support EZ Flash; http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=960&SLanguage=en-us
Happy holidays!
Mike
Dec 19, 2009 | ASUS P5PE-VM Motherboard
File P4P800SE.ROM not found
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website (www.asus.com) to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | ASUS P4P800SE Motherboard
Bios update problems P4S800-MX
An .exe file isn't a .rom file. You downloaded the flash program (the program used to flash new data to the ROM), you didn't download the flash data. Look on the site again, or look to see if there's another file - P4S800MX.ROM - to extract.
Sep 10, 2008 | ASUS P4S800-MX Motherboard
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Apr 16, 2008 | ASUS M2N-MX Motherboard
Bios
actually u know what beta means? its acutally in testing mode they r still testing n finding the errors they made so when they find all erors n fix then they launch a full version of it so never download a softwares update of such sensitive stuff which r beta version always wait for the full version to arive
Nov 09, 2007 | ASUS P4S800 Motherboard
Intel Motherboard Logo
55 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
