Question about Candy Dryers
Candy cic60 how can i locate the push/reset switch
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
IT'S WRITTEN IN YOUR OWNERS MANUAL!
OR YOU CAN DOWNLOAD IT FROM YOU MANAFACTURERS WEB SITE
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Candy cic60
your element
Mar 28, 2014 | Dryers
Hi, My candy CIC60 tumble dryer has stopped drying and the empty water light is constantly on. The timer works. I have cleaned all filter,emptied water, checked for loose wires and I can not see a problem....
Tumble dryers are really not around my neck of the woods however I have studdied them just in case they do begin to show up around here. What turns on the light and kills power to the dryer when the water tank is full? A float switch. I bet that float switch is stuck. Probably something simple like that.
Nov 29, 2011 | Dryers
Candy cic60 not giving hot air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Candy CIV60 Electric Dryer
I have a candy cic60 reverse action condenser dryer about six years old.when it is switched on i makes a buzzing noise and nothing happens apart from the buzzing,any ideas
my candy dryer when on the light keeps come on to clean fliter and the water contain dont seem to being filling up with water
Jul 07, 2009 | Candy CDC266 Dryer
Candy cic60 condenser dryer
The drum itself turns on an axle or sprocket. It may need to be oiled. The motor that turns it may be going bad. The windings and bearing could be bad. I assume it is drying O.K.
Feb 04, 2009 | Candy CDC266 Dryer
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
Cic60 candy tumble dryer
Generally, these units are gotten into from the back panel. Be sure to disconnect the power. There are two breakers linked together.
Dec 15, 2007 | Candy CDC266 Dryer
CIC60 01 tumble dryer only works if on/off button is held in
is the new on/off switch new or second hand if its new get it exchange cause these switchs have a spring in them with 2 channel cutouts in them once depressed when it starts to come back up it automatically goes into another channel which keeps it on faulty switch thats all it can be if secondhand again take it back cause its faulty this is the only thing it can be they are simply made so they dont mess up try doing it when its not on the washer love peter
Nov 16, 2007 | Dryers
Candy cic60 01 condenser dryer
check the vent line it may be cloged or bent if this is good then possibly the hi temp sensor may be bad ?
Nov 15, 2007 | Candy CDC266 Dryer
Dryers Logo
161 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
