Question about Casio Cassiopeia E-125 Pocket PC
E-125 dark screen
Has anyone had a problem on their Cassiopeia e125 with the screen going dark, like it has gone to standby mode. Even when you are working on the pda? The screen get dark almost like it has shut off, although you can barely see the screen info. It will also come back to normal for a few seconds, then go dark again. Soft reset doesn't do a thing, going to try the hard reset soon. Don't think it is a brightness or standby issue. Is it a backlight issue? If anyone has this problem or knows of a solution please let me know. Thanks in advance.
    Master:
  • 551 Answers
Have you checked the screen control settings? I had the same problem on a E-125, and it turned out that I had a screen backlight auto shutdown time that was very short - this could be the easy solution - simply adjust the auto dimming timer in the settings control. Controls setttings is a pull down menu under the "Start" button at top left corner of screen. If it's not that - then back to Casio? Good luck.
Posted on Sep 06, 2005
    Master:
  • 551 Answers
Bingo! You hit the problem on the head. If you can still see an image, albeit extremely faint, and the Casio is still working, i.e. playing an mp3 file or whatever, then you definitely have a problem with the backlight. More times than not, this is either a daughterboard problem or a connection problem (rarely have I seen an actual bulb failure though it can happen). One of the more common causes is the tiny ribbon cable connector on the daughterboard. You might try to disassemble it, clean the contacts of the ribbon and reassemble the device. I've also heard of people squeezing in the side of the case to temporarily effect repairs...this is normally more ominous.
Screen goes out periodically
screen went into sleep mode. you can set the time in system manu some where.
Oct 24, 2007 | Casio Cassiopeia E-125 Pocket PC
Cassiopeia E-125
I had the same problem with an E125 which I brought off eBay that hadn't been used for several months.
I took out the backup battery and put the main battery in it's holder with a bare wire held onto the negative & positive terminals.
When I turned on the charger, I held the other end of the bare wires onto a partly charged Nokia Battery (Also 3.7V internal). The current from this battery was enough to let the Casio start charging.
After two minutes I disconnected the Nokia battery and gently tugged the bared wires free. The Casio kept on charging happily.
After six hours I disconnected the AC charger, installed a new backup battery CR2032, and everything was go.
Aug 25, 2007 | Casio Cassiopeia E-125 Pocket PC
Need help on connecting E-125
I doubt it... I mean it is unlikely there is any incompatibility there. Go to your device manager and make sure that your USB ports are installed and configured properly for your USB cradel.
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
E-125 Will not power up ??? HELP
i made a video how to fix your dead Casio Cassiopeia PDAs.
AFAIK it works on the following models:
Cassiopeia E-10 (AFAIK)
Cassiopeia E-11 (AFAIK)
Cassiopeia E-15
Cassiopeia E-100
Cassiopeia E-105
Cassiopeia E-115
Cassiopeia E-125
Cassiopeia E-55 (= Japanese Version of E-15)
Cassiopeia E-5xx (Japanese Versions of the E-1xx Series)
Maybe it's also applicable to the EM-500 and EM-505 ...
and read the description pls :)
http://youtube.com/watch?v=l0TT5CnbwBQ
Help with E125!
Before turning off the device close all applications running in the background. If this solves your problem it is time to do a full cleanup & adding some application like Gigabar or KillMe to help you quickly close the unused applications to free required memory.
Universal Remote software?
You cannot find remote software for E-125 simply because the range of the IR emitters on E125 is simply too short. If you are willing to di some surgery on the device - switch it for a higher range one from say E-100 - the earlier versions software should work on E-125 also.
E125 screen failure symptoms
As a rule the failure of the LCD on a Casio pertains to greying out of the top 1/3 portion of the screen. The touch screen - the part that senses your stylus inputs i.e. taps, double taps, tap & hold / drag continue to work. Seems like the failure is not in the LCD but the fluorescent lamp at the top end of it. It could be the lamp itself or the inverter circuit. Have an experienced technician check the lamp out. It is not a very diffucult item to replace. Nor is there any desoldering / soldering involved.
CASIO E-125 has no backlight
Pretty common problem, and is normally one of three possibilities: 1. Ribbon cable that connects the backlight daughterboard to the motherboard connector has gone bad, or contacts oxidized. 2. Daughterboard itself has gone bad... 3. Power problem or cpu problem not activating upon powerup. Not as likely. 4.The fluorescent tube itself may has blown. The cure: carefully disassemble your 125, clean the ribbon contacts on both ends of the tiny ribbon cable, be careful, it is very fragile. If that doesn't work, find someone who has a E125 and swap out ribbon cables and see that works, that will at least tell you if the cable is bad or not. If that doesn't work, swap out daughterboards. If that doesn't work, sell it for parts on EBay and buy a new one, because anything else will probably be too expensive.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
E125 MP3 Player
You need to have your music files in a "My Documents" folder on your CFC. If they are anywhere else, the media player will not see them.
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
103 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Computer Links
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
