Question about Casio Pocket Viewer PV-400Plus
Exporting data out of Casio PV-400 Plus
Can anyone tell me how to export the data from the Casio PV-400 Plus so I can import it into a Sony Clie. Thanks,
SOURCE: Drivers for CASIO PV-S400 Plus
I think i can help you please e mail me if you are still interesing
doraalbaos@prodigy.net.mx
Posted on Oct 28, 2008
0 characters
1 Points
Palm one address database in old mdb extension how to convert to .dat extension
I am assuming you are using windows and not MAC? Since you have stated you are using MS access file format, it should be PD 6.2. There is no way to convert the file format that I am aware of.
You will need to "clean" uninstall PD 6.2 and install PD 4.1.4e.
Here is the link to PD 4.1.4e
After you install 4.1.4e, create the same username you had on the previous install of PD, close PD, navigate to c-program files-palm and find the username folder. Paste the address.dat file you have into the address folder in the username folder. Open PD and see if the data is there.
Create a new folder on your PC somewhere that is convenient. Name it something like Palm Desktop Data. (If you need help on the export the manual details are here)
Make sure you select all for the range in the export window.
With the data saved in the folder you created, make a copy of that folder and save to a flash drive, cd-rw or external hard drive.
Anytime you make a change in Palm Desktop, export the data that was changed to that folder and save again to the external media.
With this process you can always import the data back into Palm Desktop anytime you have a problem with the data in Palm Desktop or if your computer/hard drive/device crashes.
I hope that helps and I have answered everything.
Dan
Jan 14, 2011 | Palm Tungsten T3 Handheld
Copy Contacts from Palm Centro to SIM Card
When I migrated from my Palm Centro (best smartphone ever) to my current BlackBerry, I did the following: 1) Export Palm contacts from the Palm Desktop software to CSV (comma separated values or tab-delimited text) format. 2) Import the CSV file to your Google Contacts account. 3) Wirelessly sync Google Contacts to your new phone using the free Google Sync app (link below). 4) Verify data was transferred appropriately.
Google Sync details: http://www.google.com/mobile/sync/
You should be able to follow the same process for your Palm Calendar by exporting your Palm Calendar from the Palm Desktop software to a file (save the exported file to your desktop, or an easy to find location on your computer), then import the Calendar file into a NEW Google Calendar, not your primary calendar (in case there's conflicts or problems, you can delete the secondary Google calendar without losing your primary Google calendar items). Google Sync should allow you to choose more than one Google Calendar to sync with your new phone.
Dec 29, 2009 | Palm Treo 500 Centro
Contact Exporting to SIM card for HTC Dream?
Based on the following bolded statement from http://www.htc.com/ca/faqs.aspx?p_id=269&cat=78&id=99764 , I'm not sure you can do that with stock software...
Q. How do I copy Contacts from my SIM to my phone?
To copy contact entries between the device memory and the SIM card, follow these steps:
Note: Only copying from the SIM card to the device is supported.
From the Home screen, tap the Contacts icon.
Press Menu and select Import Contacts.
Perform one of the following:
Move one at a time: Press and hold on and select Import from the pop up Menu.
Move all:
Press the Menu key.
Tap Import all.
If you want to get the contacts off your phone, what I suggest is to synch your contacts with your Gmail account, and export from there to a .csv or .ical file.
Another way to do it is to go to the marketplace and download the "contact exporter" app, then export contacts as a .csv file. then you can log into Gmail and import all those contacts from the same .csv file. this will automatically sync over the air with your another Android phone. Very easy.
Jul 02, 2009 | HTC Touch P3450 Smartphone
How do I export contacts from a Palm 650?
First thing what is your new phone you using now?
If still the same palm operating system,what you need to do is just 1.export your contact from your palm desktop.After that you create a new ac for your palm desktop then import the file you export just now to the palm desktop again.If you are using windows mobile repeat the number 1.then go to your active sync user ac and import from the file you export just now.
Dec 28, 2008 | Palm Treo 650 Handheld
Oct 15, 2008 | Casio Pocket Viewer PV-S400 Plus Handheld
Not able to synchronise
did u set the pc-sync up to use the correct com port? got menu, then, casio, then, transmission setup and configure correct serial port.
Feb 04, 2008 | Casio Pocket Viewer PV-S400 Plus Handheld
Transferring Files
Many years ago I transfered my SHARP organizer files too my first Palm III. The Sharp offered a file export option. I exported to CSV format and then from CSV to the Palm pdb. Check the CASIO boards also.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio Pocket Viewer PV-400Plus Logo
Top Casio PDAs Experts
k24674
Are you a Casio PDA Expert? Answer questions, earn points and help others
