Question about Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist Watch
Stop Watch not resetting
The Start hand for the stop watch (rod top) has moved back 2 min to the 58' position. When I start and reset the stop watch it wont go back to the "12 o'clock" position. The miniute hand (again the stop watch function) is on the 6 and the hour hand (third circle of the stop watch) is on the 5 position.
HOw do I reset this all back to the start positions?
    Problem Solver:
  • 18 Answers
Pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Posted on Jul 09, 2009
DO NOT REMOVE THE HANDS ON YOUR WATCH!! pull crown out to second position then press button on dial you want to zero out. each time you press it, it will move 1 increment
Posted on Sep 14, 2008
  • 111 Answers
You need to remove the hand of watch and fix it at the correct position
Posted on Aug 27, 2008
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
How do I reset the millisecond hand used in the stop watch function on my nixon Ride SS watch?
Try this:
Resetting Chronograph Hands:
Note: Some Nixon watches come equipped with a "screw-down" crown; the crown must be unscrewed by turning it counterclockwise before it can be pulled out)
1. Pull the crown all the way out to position 2.
2. Push the crown in slightly to position 1.
3. Push top pusher button to advance the second hand to line up with the 12:00 position
4. Push the crown back in. (Make sure it is screwed in if it is a screw crown)
Jan 02, 2014 | Watches
How do I set my pod 535 watch after I have changed the batteries
Just tried this procedure to replace a watch battery in a POD 535 and did not work...my version of the watch might be different, all I am saying is it did not work with my watch.
The procedure that worked with my watch
When you have replaced the battery reset the watch by placing a small screw driver across the two recessed contact next to the lower battery clip. The digital display will reset and you will see four zero's flashing...if not press the winder button once, or reset the watch again. This process is to get all the hands at twelve O clock position...press and hold the top right hand button and the hands will start revolving...you can let go of the button once the hand are moving. Pressing the top button again will stop the hands and a short press will move the hands in small increments. Once the hands get close to 12 press then press the button once and then press the same button in short pulses to align all the hands on the 12 position. Wait a short time and the watch will find the time signal and both the digital display and hands will be aligned and showing the correct time.
Oct 29, 2011 | Garmin Forerunner 50
I have a police chronograph watch about a year old if that and the chronograph dials have reset themselves at random points does anyone know why and if so is there a fix? many thanks david
hi,
all you need to do is pull the centre bezel out (to where you adjust the time) and by pressing the top button the chronograph needle will move round. Once it is the correct place simply push the centre bezel back in.
Hope this helps.
Duncan
Dec 17, 2009 | Police Watches
Cant set the second hand to move
The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
This is a timer dial. ["Stopwatch 1/5 Second Hand"]
To start/stop this, use the top button (Button "A").
To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A".
The "second" hand is the small dial at the 9 O'clock position.
In actuality, you 'could' start this and just not stop it...  Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
Nov 11, 2009 | Pulsar Chronograph Watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Stop watch hand
You have to reset your watch. Pull out crown to first click and try to move stop watch hand by pressing one of the pushbuttons. If this do not work, push the crown back in. Now pull out crown fully tto the second click and try to manipulate with pushbuttons again.
After resetting stop watch hand to 0 push the crown in completely.
Job done.
Nov 28, 2008 | Watches
The stop watch second and minute do not reset to 12 . Dallas
To reset the stop watch unscrew the stem and pull it out 1 click. Then press the buttom to the top of the stem and it will move the minute stop watch 1 minute continue to press to get it set to 12. Do the same with the bottom button to get the second hand stop watch to 12.
Sep 01, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist Watch Logo
1,068 people viewed this question
Top Tag Heuer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
