Question about Optoma HD72 Multimedia Projector
HD72I WORKS FOR 30SECONDS AND THEN SWITCHES OFF
  • 2 more comments
  • Anonymous Sep 07, 2008
    I have same problem after 1100 hrs on my bulb.
    I bet the fan is also causing my over heat condition.
    Will try cleanning lens and filters first next week.
    Will try to replace fan on my own if that doesnt work.
    Thanks for the tip.
  • phillyfinest Sep 07, 2008
    My projector don't warn me of short lamp life. My lamp was replaced with a new one and it only last about 1000 hrs. in cinema mode.
  • serco 2000 Dec 22, 2008
    I have the same problem, screen is clear and cleane for 20-30 second, then the lamp close, everything else is normal.
    close it. open it and still the same thing.
    Need help? Thanks
  • Spitty Jim Jan 08, 2009
    Sounds just exactly what has just occured with my projector, just wondering whether the fan replacement was sucesssful in other peoples cases.
    Problem Solver:
  • 5 Answers
I had this exact same problem. I have changed bulbs gotten 1000 or so hours from new bulb, changed the lamp driver and gotten about 600 more hours from new lamp driver. New lamp cost me $350, lamp driver cost me $120. Then I read on a page to try and flip it right side up, because I had it ceiling mounted upside down. I flipped it right side up and it works perfectly and has been working perfectly for 2 months now. I know it sounds stupid, but it actually worked for me, and it costs you nothing to try it. For some reason, gravity effects this unit. Good luck.
Posted on Feb 05, 2009
I had the same problem with very few hours on the lamp. Sent it back to the factory and they said the fan was overheating causing the bulb to shut down. They replaced the fan and the bulb for free under warranty. I noticed before I sent it the projector was putting out an incredible amount of heat. MUCH better after fan replacement.
Posted on Aug 28, 2008
Yanmar 4TNV88 engine starts,then cuts out after 20-30seconds
It sounds like there is a fuel flow problem. There is a restriction either in the tank or fuel filter that lets enough fuel through to start the engine, but not enough to keep it running.
Mar 17, 2014 | Electrical Supplies
Will not switch on
Remove the power plug and battery. Press power for 30seconds to discharge the system. Connect the power plug but not the battery and press power. That may work,
Nov 18, 2013 | Toshiba Tecra M5-S433 Notebook
My ua55d6000 keeps switching off???
Hi there. Did you ever find out what caused this? I have the exact same model and problem. Thanks
Jul 14, 2013 | Samsung Ua55d6000 55" Led 3d Smart Tv For...
Optoma Themescene HD72i - Color wheel glass loose
Dear David,
i have Optoma projector HD72I color wheel,
please patiently wait for some days, once i post it on Ebay, i will inform you at the first time.
lets keep in touch with freely,
best regards,
Jack
Nov 14, 2011 | Optoma HD72 Multimedia Projector
How to rest t
Connect the switch with a null-modem cable
In windows, hyperterminal , To enter into Password Recovery Mode:
login: recover
password: recover
Turn the power off (hard reset) within 30seconds
Re-enter the password twice.
Feb 23, 2011 | 3Com SuperStack 3 4228G (3C17304-US)...
My dell mini inspiron doesn't work when i turn it on; it starts but then nothing, it is obvious that it is on but it is only a black display on the monitor. What could be the problem?
You can switch it OFF and remove the battery.
Wait for 5mins, Connect the battery again, Also connect the Power Cable to the Laptop.
Try to switch it ON, It should work.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 08, 2010 | Dell Inspiron Mini 10 Notebook
I have a Polaroid FLM-323B LCD TV. Hooked up to an antenna, I cannot get to the HDTV tab in the menu section. When I hit the HDTV tab the screen goes blue and no remote button works until you hot the...
Hi
try resetting all menu option to factory default and see if anything change.
When resetting the menu, switch the TV off, pull the plug from the socket for about 30seconds and switch back on.
hope it helped
TekspotCoUk
Sep 07, 2009 | Computers & Internet
Have drained and cleaned out a hpl103/105 hot tub left it for 1 week while on hols refilled and switched on starts pumping water through jets for about 30seconds to a minute then trips main house RCD ??...
Try disabling the heater and recheck. Unplug each component to control pack to identify which is causing gfci trip. This will isolate problem units or controls.
Mar 31, 2009 | Pool & Spa
Did you figure out your KVM?
if you tried to connect your mouse to the keyboard port and still it doesn't work. Power cycle meaning unplug the KVM from the CPU, monitor, keyboard and mouse. Then wait for about 30seconds before reconnecting again. If you still encounter the same problem that the keyboard port won't work then it means that keyboard port is defective. Replace it.
Jul 27, 2008 | IOGear GCS632U 2-port KVM Switch
Optoma HD72 Multimedia Projector Logo
327 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
