Question about HP Office Equipment & Supplies
I have a D7300 printer serial No Q7057B bought from Staples about 6 weeks ago. The message appears on screen: "Ink system has failed. Unable to print". I have turned it off and removed the power cable for 10 seconds on 3 seperate occasions but no good. What do you advise?
  • 1 more comment
  • hmaund Aug 27, 2008
    Ther are no OK or Help buttons on the printer. Where are they?
    How do you reset the ink counter?
    I have not done a test print but the warning signs have gone.
    If I cannot print I will come back to you.
    Hugh
  • HP Master
  • 6,487 Answers
Try this one:
Reset the Printer to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Now please unplug and re plug the power cable at the back of the Printer.
Hope that helps......
Posted on Aug 27, 2008
  • Mark Gil
    Mark Gil Aug 27, 2008
    Ok its for a different model number try this instead:
  • Press the On button to turn the printer off.
  • Unplug the power cord from the back of the printer.
  • Remove all the ink cartridges.
  • Wait two minutes.
  • Plug the power cord into the back of the printer.
  • Press the On button to turn the printer on.
  • Install the ink cartridges when prompted.
  • Hope this helps........
  • HP Master
  • 19,396 Answers
You need to reset printer ink counter.
  • Ginko
    Ginko Aug 27, 2008
    Try the following reset procedures:
    procedure 1
    1: turn on printer and wayt for it to get ready
    2: unplug powercord
    3: press '6' and 'Select Photo'(most right of the '6') button and hold pressed
    4: plug in powercord
    5: keep holding key's pressed until display shuts down
    6: release buttons; message "Semi NVM Reset"
    procedure 2:
    1: press simultaious "arrow left" + "arrow right"
    2: enter '1 2 3'
    3: this wil get you in to mfg menu
    If they do not work you need to clean the contact to cartridge sensor, that is located on cartridge carriage with soft cotton and printer cleaning solution or isopropyl alcohol. If you use alcohol be careful not to spread it on the printer head.
    Now someone can post here the Best solution, as usual.
  • Ginko
    Ginko Aug 27, 2008
    "Techexpert12: you do not have a clue, just stop with your attitude before we all get upset.
    Apologies to the user.
    From page 123 of user manual here:
    Error message: Ink System Failure
    Solution The print head assembly or the ink delivery system has failed and the
    HP Photosmart printer printer can no longer print.
    Turn off the printer, then unplug its power cord. Wait about 10 seconds, then plug it
    in again. If this does not clear the error message, please contact HP Support.
    Often this problem is given by a patine of dirt on the printer carriage sensor, that is the plaque iside the printer carriage.
    Try cleaning it, if it does not work, then printhead is reallly defective and must be replaced.
  • HP Master
  • 1,879 Answers
Fairly new printer & the ink system is already failing ?
Probably the inks are the ones that came with the unit.
2 options : Get a new genuine replacement ink OR call HP tech support for a replacement.
    Master:
  • 521 Answers
Check the internal cables
  • 1 more comment
  • tech expert12 Aug 27, 2008
    it causes sometimes due to loose cables.otherwise its definately a cartridge problem ,may be colour or black or both.pls do check by replacing cartridges too.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
    its a cartridge problem .plse check.there are no OK and help buttons as per my knowledge.so just check with new cartridges.it will work fine.thanks.
    thanks.
    regards.
    fixya expert team
    i would again suggest thatits a cartridge problem and replacing the cartridges will solve ur problem without disturbing any printer settings.thanks.
I am getting the message "Ink System has failed. Unable to print. Refer to printer documentation. Error:0xc18a0001." I have tried to shut it down and back on and it's still not working -...
1. Get the unit into the "Support Menu" by following the steps below according with the product,
A. - Press and hold the "left arrow" key.
B. - Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release the "OK" button
2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. If the error is still there, or reoccurs replace the unit.
VOTE ME IF YOU LIKE THIS SOLUTION
Aug 12, 2011 | HP PhotoSmart C5150 All-In-One InkJet...
Tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
on Jul 15, 2011 | Office Equipment & Supplies
Ink system has failed.Unable to print. Error:0xc19a0021.What can I do?
Hewlett Packard Ink System Failure Error Fix (tested C6180) 1- Press and hold the "*" key. 2- Press the "#" key and release both keys. Display should say "Enter Special Key Combo" 3- Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M 4. Press and release the right arrow button until the display says "System Configuration Menu". 5. Press and release the "OK" button. 6. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 7. Press and release the "OK" button. 8. Display should say "Hardware failure status: Clear. Press OK to clear". 9. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 10. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 11. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 12. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 13. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
I hope this helps Regards GM
Jul 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
Hello my printer model in an HP Photosmart 3210 All in one, it was working okay until I replaced one of the empty ink cartridges and now I just receive this message, "Ink System Failure, Ink system...
Greetings sometimes when this happens is that the printer cartridge is not accepting that as the correct model I recommend you go where you bought it and ask for another because this is not working, I recommend getting one new one that is not Refil
Dec 29, 2010 | Office Equipment & Supplies
On the printer small screen it gives me this message. Ink System has failed. Unable to print. Refer to documentation error 0x05d1281 A short time ago a paper jam occured, I believe this current problem...
You can try clearing this error by resetting your printer. Follow these steps, Its worth a try.
1. Press and hold the “*” key.
2. Press the “#” key and release both keys.
3. Display should say “Enter Special Key Combo”
4. Press and release in sequence the “1”, “2” and “3” buttons.
5. Screen should say “support” R0631M”
6. Press and release the right arrow button until the display says “System Configuration Menu”.
7. Press and release the “OK” button.
8. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
9. Press and release the “OK” button.
10. Display should say “Hardware failure status: Clear. Press OK to clear”.
11. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
12. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
13. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
14. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
15. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer
will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
16. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Let me know if this help you.
Thank you for using Fixya.
Aug 21, 2010 | HP Photosmart C6280 Printer
HP 6280 INK SYSTEM FAILURE
Try This :
First check with a new set of orginal HP catridge ; if still it doesn't work then the printer needs to be replaced ; call HP if the printer is in warranty they will do it free of COST ; No. for HP is : 18004746836;
Sep 16, 2009 | HP Photosmart C7280 Printer
I just purchased an HP Photosmart C7200 All-in-one printer, loaded the ink cartridges and the screen says the magenta cartridge appears to be missing or damaged. I put in a new cartridge- same message...
Hi
If the printer is out of the Box, don not try any other ink cartridges, becoz you must use the HOST ink cartridges that is shipped with the printer for the first time.It seems that it is problem with Host ink cartridge.
You can check the cartridge whether its a Host ink cartridge or normal one by looking at the serial number.If Serial number starts with C9, it Host; if it starts with C8 its normal one.
Only HP can replace it , none of the store sells Host ink cartridges, they sell the replacement ones.
You can either call HP tech support or, return the printer to staples.
Thank You
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP Office Equipment & Supplies
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
New Ink cartridges registering as empty ...
Is it an HP printer? We had the same problem at work with print cartridges purchased at Staples. They have a major quality control problem. Your new print cartridge may be empty or dried out (died on the shelf). It's my problem at work, as I have over 80 HP deskjets, and Purchasing still insists on buying the Staples cartridges rather than the HP.
Sometimes if you shake a print cartridge really hard it may correct the problem. However, I would buy or borrow a black HP print cartridge and try it out in your printer. Works almost every time on the job. Good luck.
Apr 17, 2008 | Computers & Internet
how old is this one? And sometimes, those 'replacement' cartridges are anything but standard.
recycle your printer responsibly
Mar 16, 2008 | HP Photosmart C4180 All-In-One InkJet...
1,066 people viewed this question
Ben Johnson
