Just bought a 7inch prism jc705e i turned it on was ok just fuzzy picture so when i was pressing remote red light went of and it wont come back on
ctf1800
  • 4402 Answers
SOURCE: will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Posted on Feb 12, 2008
SOURCE: Green screen with red and blue wavy lines
This is "NOT" meant as "expert" advice...as this is not my area...HOWEVER...I see no one has answered this yet...AND I got some good help from here a year or so ago that worked for me!
When I had a similar "green screen" problem with my SONY projection tv...the guy helped me by having me make "MINOR" adjustments to the red/blue/green etc knobs behind the panel. These were three small black plastic pieces and needed less than a 1/16 of an inch adjustment...try adjusting one at a time and giving it few seconds after each adjustment. It worked for me..at least for a while (till my wife gave it away to a friend because it was "too big"...ah! women!!! LOL)...hope this helps. (NON-expert help!)
Posted on Jan 11, 2009
Ecollier2012
  • 3459 Answers
SOURCE: 9p6040 c102 philips magnavox rear projection tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 16, 2009
techman007
  • 1112 Answers
SOURCE: WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Posted on Nov 28, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Green Background with red wavy lines
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 07, 2010
97 geo prism automatic. Car ran fine yesterday.
triple posted now. and still anon.
back up and read all answers and answer the questions asked.
Sep 23, 2014 | 1997 Geo Prizm
Turn the tv on picture come on all red and fuzzy and then couple seconds later tv turns off and then turns back on with no picture just red screen then turns off and wont turn back on for ten min
It indicates a short at the Red picture tube--set has three picture tubes and each has a socket which processes signal to each tube--each has a single IC chip---in your case either the chip on the red board or the red tube.
If a bright red screen the set will detect something is pulling way too much current and shut the set down for protection---called a shutdown circuit.......
Apr 13, 2012 | Televison & Video
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
Mar 08, 2017 | Element ELCHW402 40 in. LCD HDTV
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
I have a sears tv thats a tube tv.I have digital cable and i programed the remote.I pressed PIP on off button and my tv went dark and wont shut off.I have to unplug it.Now when i turn it on the tv it is...
Old-timey tube TVs can't handle PIP. In fact, some old DLP TVs would be in danger of physical damage should you even attempt to output progressive signal.
As such, it's likely that your TV has given up the ghost. Might be time for an upgrade.
May 06, 2011 | Televison & Video
Recorded play back is fuzzy
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Apr 21, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
My pictures turn out fuzzy all the time and i can't figure out how to turn on my flash. Please Help! Casio Exilim EX-Z70
Flash should turn on by pressing the "Set" button and then the down arrow until you get to the flash menu. Choose the setting that looks like a lightning bolt.
If that doesn't work press the "Menu" button and then press the "right arrow" until you are on the far right tab. Press the "up arrow" until you come to "Reset." Press the "Right arrow." The camera will ask you if you want to reset it. Tell it "Yes." This will take it back to factory settings and clear any mode that turns the flash off.
Are the pictures fuzzy because the flash isn't working? Are outdoor pictures in daylight fuzzy or OK? If they are fuzzy all the time you may have a lens problem. If they are only fuzzy when the flash is needed, fixing your flash should cure the problem.
Dec 18, 2008 | Cameras
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
TV WONT TURN ON
try pressing the channel or volume buttons. They turn on the tv as well. Maybe the the remotes might cooperate with the tv.
Jul 22, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
Electro Med Services...
