Question about Onkyo DV-C601 Multi-disc DVD Player
No Disk error message
Does not play DVDs. Gives error message "No Disk" even though loaded with 1 or more DVDs.
  • Anonymous Mar 19, 2014
    wont play newer dvds
I was able to fix the problem by buying a disc lens cleaner at an electronics store and allowing it to "play" for 1-2 minutes. Was also told you could possibly clean the laser-reader with a cotton swab soaked with rubbing alcohol. Otherwise the laser-reader may be bad or out of alignment.
Posted on Oct 20, 2008
I have the same problem. I opened the DVD player up and "blew out" dust. Still does not recognize that I have a disc in. HELP
Posted on Oct 19, 2008
Sony dvp-ns57p plays cds, not dvds
COMO PUEDO DESBLOQUEAR EL VIDEO DEL DVD
Nov 20, 2012 | Sony DVP-NS57P DVD Player
It plays CDs, but not DVDs even after the laser lens cleaner that fixed my home theater dvd. When you load in a dvd, it clicks three times, says load, clicks three more times, then has disk error message....
Time to get a new one, probably. The laser for DVDs is different for CDs so the DVD laser or a component in that section has probably failed and at today's prices, get a new player with morre features for less than you paid for this one. You can keep it for CD playing. The fact that it plays CDs means most of the player works except the DVD laser circuit. You might look at the lasers with a magnafying glass (Unplug for 1 hour before that look) to see if you can see the 2 laser lenses and one is dirty. Not very likely fixable but it is a free try. Good luck.
G
Mar 03, 2011 | Philips DVD750VR DVD Player/VCR
I keep getting a Bad Disk error when loading DVDs that I know are fine. When there's no disk loaded, all I see is the blue load screen with the message "loading" in the upper left
there is a ribbon cable in the DVD player that connect the moving laser head to the main circuit board. When this cable becomes damaged from moving over time, it will claim that your DVD is bad (even though it is not). Best to scrap the player and buy a new one.
Oct 07, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD will not load
Firs try to clean the lens with CD/DVD cleaning disk (it might be $1-5 depending on store)
Also check if DVD disk not upside down.
Also chek the DVD disk for scratches
Good Luck
Dec 25, 2008 | Daewoo DVG-9200N DVD Player
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Home burned DVDs won't play in regular players
you need to select the disk as audio disk in the burning application, then select tracks and burn it.
Dec 20, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Used a Maxell Lens Cleaner product. Let it cycle through 2 - 3 times.
Aug 27, 2008 | Audio Players & Recorders
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Invalid disk
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's but avoid memorex brand. Usually any other cheep brand will work.
May 04, 2008 | Gateway AR-230 DVD Recorder
Onkyo DV-C601 Multi-disc DVD Player Logo
463 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
