To connect your camcorder to a TV (or VCR), you'll need audio/video cables. These need to be run from the VIDEO and AUDIO jacks on the camcorder to the VIDEO and AUDIO inputs on the TV (or VCR).
Once cabling is completed, follow either of these scenarios:
When connecting the camcorder directly to the TV, turn on the TV and tune it to the video input channel by pressing the INPUT button on your remote control.
# When connecting the camcorder to a VCR that is already connected to a TV: Turn on the VCR and place it in the Line or Camera mode.
# Operate the TV as you normally do to see the signal coming from the VCR.
Select camcorders have an S-VIDEO jack, which offers higher video quality. Provided your TV or VCR has an S-VIDEO input jack, connect the camcorder to the TV or VCR using an S-VIDEO cable. Since the S-VIDEO cable only transfers video, you will also need to use an audio cable. Select the S-VIDEO input on your TV or VCR to view the signal coming from the camcorder.
This sounds like an internal operating problem. I suggest taking it to the store where you purchased it. Hopefully it isn't too old yet, it is a common problem for older/used cameras to have. Hope that helps.
You need to hook Mini jack to RCA video cable between camcorder AV Out and TV AV Input to watch tape playback picture on TV screen. Above said cable is available in Radio Shake and Amazon etc.
1 - To start with.. Plug aerial lead into the "RF input" on rear of vcr --> now you can tape programs (providing vc is "tuned" correctly)
2 - Plug a lead from "RF output" into tv's "RF input" --> now you can watch programs on tv _independently_ of vcr (ie can be watching 1 program & taping a separate one on vcr)
3 - Plug red/white/yellow cable from vcr's "VIDEO/AUDIO output" into tv's "VIDEO/AUDIO input" --> now you can 1) play a tape in vcr, & watch it on tv & 2) change what watching on tv via vcr's remote
* Note: This is for analogue terrestial television (aerial on roof), not digital/satellite tv, connecting to stereo, etc, etc (the "more involved " setups)
there should be a pair of rca (red,white,yellow) wires that came with the camcorder.....if you cant find those try going to radioshack or a nearby electronics place and tell them what you need to do and they will get you what you need. now for watching them on your tv....if you tv has the rca inputs usually attached to front of tv you can plug it in right there and switch the tv over to another input like video 1,2,etc sometimes it will say "line" instead of video.
If you have had the camera for a long time, it may have simply died. This may not help, but you could leave the camera on untill the battery loses all power, then try to turn it back on, and see if it works.
try a cleaning tape first - best not to rewind
the cleaning tape because it will put back the
crud previously removed ? into your heads and
guides ( last tape to play is prime suspect ) ;
digital heads wear faster than analog so a
new set of heads is next possibility but if the
cleaning tape works . . . retire your library
soon as possible .
