Question about Onkyo DV-C601 Multi-disc DVD Player
No Disk error message
Player gives No Disk error message even though it has DVD's in it.
  • 6,487 Answers
The only reason why its giving you the error is because the player cannot read the DVD , the cause for that are the DVD is bad, so try a different DVD and check if it will play if it did play the first DVD is really bad, But if it still did not read a different DVD in means the lens of the player can be dirty or bad, try to run a CD cleaner to clean the lesn of the player if still the same the lens may need a replacemnet already..
Hope that helps..........
Posted on Aug 27, 2008
    Master:
  • 521 Answers
Lens is weak if dvd is fine
  • tech expert12 Aug 27, 2008
    lens goes weak or gets misaligned after some particular time ans so its not able to read the disc n the player shows no disc.one more possibility is that,there may be some moisture or some dust on the lens which causes this problem.if its dust or moisture problem u can just clean it with a lens cleaning dics or open the device and clean the lens manually.but if its alignment or lens weak problem ,u will hve to get it repaired through technician .it will cost very minor charges.nothing much to worry.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
Problem playing dvd with panasonic sa-pt660 keep getting an H02 error message?
Thousands of annoyed customers of Panasonic, Yamaha, and Denon DVD Player owners have encountered the infamous H02 / H07 /H03 erors and many others on thier players or maybe the "No disk" error even though a disk is in the drive. Well many people have spent hundreds on repair or bought a new unit. But i am here to tell you that it is okay to open up your dvd player and mess around in side. If your DVD player comes up with one of these errors the first thing you might want to try is to open up your DVD player by removing the screws on the side and the back (depending on the model), then plug the dvd player into power outlet with cover removed. Stick a disk in and press play and give the disk a little push. Most of the time the Spindle motor is dieing out when you get a H02 error. In this case that little push may get your spindle motor to rev back up back into action. And if your as succesful as me then hopefully you have just fixed your H02 error for free without doing much work. I just got a Panasonic HT95 Reciever/DVD player to play all disks again by giving the motor a little "kick start"
Jan 05, 2011 | Panasonic Televison & Video
How do i fix my CD player? when i put a disk in, the readout says "err disk" it works every once in a while, but i have run a lens cleaning disk in the player, and it wouldnt even read that disk.
how long have you been using the player? And has it been giving you this type of problem before now?
I think the fault is from the laser (lens) of your player. The lens is very weak such that it cannot read the data or files on a disc, that's why it should disc error, even though it plays some disc but that doesn't mean its not a lens problem.
You need to look for a way to replace the lens for your player so that it can play all discs perfectly well again.
Good luck.
Sep 25, 2010 | XO Vision XO9013 Car DVD Player
My dvd player keep on loading but it end up no
from direct experience, the problem is that the disk does not start spinning by itself - it will if you have the top off and give it a spin to start it ... I don't know what the ultimate solution is though.
Jul 04, 2010 | Pioneer DV-400V DVD Player
I keep getting a Bad Disk error when loading DVDs that I know are fine. When there's no disk loaded, all I see is the blue load screen with the message "loading" in the upper left
there is a ribbon cable in the DVD player that connect the moving laser head to the main circuit board. When this cable becomes damaged from moving over time, it will claim that your DVD is bad (even though it is not). Best to scrap the player and buy a new one.
Oct 07, 2009 | Cyberhome CH-DVD 300 DVD Player
Disc is not working. Error message No disc
Try cleaning both the disk and the lens of the dvd player. Sometimes even a little bit of dust can make your dvd player go ballistic. Brands like Sony,Philips and LG are very sensitive. If anything else fails, you can take it to a repair shop to find out if the lens isn't cracked or the LED isn't responding while trying to read the disk.
Apr 02, 2009 | Philips DVP3960
DVD will not load
Firs try to clean the lens with CD/DVD cleaning disk (it might be $1-5 depending on store)
Also check if DVD disk not upside down.
Also chek the DVD disk for scratches
Good Luck
Dec 25, 2008 | Daewoo DVG-9200N DVD Player
Used a Maxell Lens Cleaner product. Let it cycle through 2 - 3 times.
Aug 27, 2008 | Audio Players & Recorders
I have the same problem. I opened the DVD player up and "blew out" dust. Still does not recognize that I have a disc in. HELP
Aug 27, 2008 | Onkyo DV-C601 Multi-disc DVD Player
No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
Apr 16, 2007 | Durabrand PVS1966 Portable DVD Player
DVD player shows "no disk" messege even though there is a disk in the player
Either a disk problem, or a player problem. If you get the "no disk" message when using other disks(try originals if you were trying burnt), that aren't scratched, then it's possible that the lens needs cleaning. open the player, locate the lens, and gently brush off any accumulated dust. If you see none, then it will take a more serious repair, possibly to the motor assembly, or the lens mechanism. Good luck
May 03, 2006 | Akai DVDP5851 DVD Player
Onkyo DV-C601 Multi-disc DVD Player Logo
391 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
