Question about Zanussi 23 in. ZKT641H Electric Cooktop
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
Hello,...my prob is.....
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up - buttons etc all function fine and all other zones work fine..any ideas?
  • 1 more comment
  • Anonymous Mar 12, 2014
    Candy CH64C Ceramic Electric Hob - locked
  • Anonymous Mar 19, 2014
    i have a zanussi zit64x induction hob with brown black blue yellow/green wires how do i connect them to the mains
    President:
  • 1,462 Answers
Can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Posted on Aug 28, 2008
    New Friend:
I am having the same problem have you found a solution yet?
My front left hob does not seem to detect the pan. It shows f
Posted on Mar 31, 2013
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
My Zanussi Induction cooker model ZKT 621LX is not working? When I try to switch it on, the display for all 4 cooking zones shows L and after a few seconds, it just shuts off? What could be the problem?
Hello Horus,
The child-lock has been activated - probably accidentally, but someone may think you're not safe to use it. The de-activate the child lock . . .
1. Switch the cooktop on so all zone show "L"
2. Press both the + sign for the right-front zone and the - sign simultaneously. All four zones will show "0" with flashing decimal points.
3. Press the - sign again. The cooktop will switch off.
You can now switch the cooktop on and use it normally again.
Hope this helps. If you have any difficulty de-activating the child-lock or need further assistance, please let me know.
Regards,
BElectric.
Apr 19, 2011 | Zanussi 23 in. ZKT641H Electric Cooktop
Back L element no go
Feel free to download a copy of your wiring diagram from http://sparepartspro.zendesk.com/entries/118713-zanussi-electric-hob
Qualified Electricains only.
Feb 24, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
Have a baumatic ceramic hob displayin letter 'L'
the solution is already on fixya i just tried it and it works.press the right key and the minus key at the same time release the right key hold the minus key for 10seconds and the L will disappear
Jan 25, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
When i switch my zanussi hob on L comes up on all 4 zones.Could you tell me what is wrong Model no.ZKT641F.
Turn on so that all are showing L
Then press - for 5 seconds when all should show 0 then turn off.
Upon turning on all should be fine.
Sep 09, 2009 | Zanussi 23 in. ZKT641H Electric Cooktop
Left hand side not working
OK. I know whats wrong. On your terminal I guess you only connected the Large Brown wire to the number 2 terminal ( Live ) What you have to do is bridge terminal 1 and 2 together. You may need to peel back the heavy copper brown so you can split it evenly and ensure it can reach to terminal 1 and 2 . So what you have then is one cable feeding to both 1 and 2 terminal. If you have the smaller live brown wire just connect that to terminal 2 also. That should fix your problem. I will check back to see if you have any more problems..
Sep 16, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Zanussi 23 in. ZKT641H Electric Cooktop Logo
1,407 people viewed this question
Top Zanussi Cooktops Experts
fyigen
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
