Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
DWL-G710 - Not able to logon with standard IP-adress
If hte standard IP-adress have been changed, is there a command I can use to ping the router and see the current adress? If I press the reset-button I thought the IP-adress is set back to standard? The router has been used, but after changing internett-supplier I must do changes to this extender, but now I'm not able to log on.
Must have same IP-adress on Router and Repeater 192.168.0.x. Then have cable from router to PC and from router to repeater. Then logon to repeater and the Dlink-repeater SW have a command where you can see available networks. See to that you choose the right one and that channel, name and password is the same as the router. The repeater will not be visible when you search for available networks because it has the same name as the router. I also had to restart the router and the repeater before it worked.
The repeater gives us excellent connection where we otherwise has no connection, so I can recommend it.
Posted on Sep 02, 2008
Trouble logging into a D-Link DWL-G710 Wireless
Let me try to get the info straight:
Your computers IP address (manually configured):
D-Link Range Extender IP:
If this is correct, you will need to change your IP to something like:
192.168.0.X (make sure it's not in use on your network already)
otherwise you will not be able to connect to it with your comptuer.
Apr 03, 2010 | D-Link AirPlus G Wireless Range Extender...
Range Extender DWL-G710 & Wireless N Router DIR-615
Try to configure your new router and you have to reconfigure the Range extender to tally with the new router. The IP Address that the range extender should have should depend on the DHCP server of your router that provides the IP Address.
Jan 12, 2010 | D-Link AirPlus G DWL-G710 Wireless Range...
How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from to
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 won't connect to
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be not
Oct 18, 2009 | D-Link AirPlus G Wireless Range Extender...
Can't access the internet. No problem with the static IP address and setting up the DWL G710. Searched and found 2 AP's for my wireless account. Selected one and saved. Got indication that DWL G710 was...
Is there any particular reason you're using a static IP? Most routers are set up already for DHCP.
If you need to use a static IP, make sure you have the right settings for the default gateway and DNS servers (you'll have to contact your ISP to find out the addresses for the DNS servers).
I would recommend switching to DHCP though, and you won't have to worry about such settings.
Aug 02, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
1- connect through ethernet
2- the default ip @ is (check the manual :)), mask is [make your pc in the same subnet]
3- enter the adress in your browser
4- default user is admin, default password is blank (nothing)
5- run wizard (click the button)
6-go to admin tab , you can set your password there
hope this helps, let me know
Apr 01, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
I can't get to
I did this with Windows 7 but the same solution applies to Vista and XP.
1. Connect the Range Extender (mine happens to be the DWL-G710) by cable to your computer. 2. Open the Network and Sharing Center. 3. Click on the connection, then on "Properties" 4. From the list select "Internet Protocol Version 4 (TCP/IPv4)" and click properties. 5. Select "Use the following IP address" 6. Use the following settings: IP Address: Subnet mask: Default gateway: 7. Click OK then Close. Give the computer a few seconds to re-establish the connection. 8. Go back to your browser and type again. It will work. 9. Don't forget to go back once you're finished and change the setting back to "Obtain IP address automatically."
Also, it's a bad idea to use WEP encryption as any password you would use is easily crackable within a few minutes using the Aircrack suite of hacking tools in Linux. Even someone using Windows can use a live Linux distribution such as BackTrack which is bootable from a CD to hack in and get your password. Once they have it they're in and use your internet connection.
Use WPA-PSK encyption or better and choose a password that can't be found in any dictionary or on the web. It can't be hacked as of yet.
Feb 19, 2008 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Sep 16, 2007 | D-Link AirPlus G Wireless Range Extender...
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
782 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
