Question about Panasonic DMR-EZ47V DVD Recorder/VCR
No TV response after power outage
We had a power outage today for several hours. When power was restored, the Panasonic unit woke up again, however, nothing shows up on the TV screen. I can't see any menu's, channels, nothing but blue screen. I tried to reset the default settings, but I'm not even sure if I've done that.
Is there any way you can reset the AV channel on a TV?
  • 1 more comment
  • Lilly76 Nov 04, 2008
    I also had a power outage. Unit was plugged into a wall outlet. Cannot use the remote for anything but to turn unit on. On display, the progressive icon (a "P") is all that shows up. Pressed "reset" button, held down power button for 10 seconds, unplugged...no luck. Sometimes I get a different msg., but still cannot use the remote or buttons on actual unit again except the power button. I did change batteries in remote, but that did nothing. I don't want to give up on this darn thing, but don't want to spend over $100 to have it fixed as instructed by customer service. HELP!
  • lnst676 Dec 11, 2008
    simaler problem -dmrez475vk,didnt have power outage,moved recorder to differant room pluged it in! only shows 00000 and flashing 12:00am time no control with remote!!what going on tried all reset options still nothing. is there a secret reset sequence?help!! thanks lnst.
  • ee-sparky Dec 26, 2008
    Same Problem as Inst676 - display scrolls though 0's or flashing 12:00 AM but will not respond and no resets seem to help. A peek inside the case shows the LSI chip on the digital board screaming hot and no fan turn on. Could the digital board be blown?
  • 70 Answers
Check you scart lead at both ends
Posted on Oct 05, 2008
I have a Panasonic plasma, & we just had a power outage today... every time we have one, it won't power back on. The call center is closed for the night, & I can't remember what they told me to do the last...
First, unplug the TV, wait 30 seconds to 1 minute, then plug back in & try it. This allows the unit to reset.
Be sure you AC outlet breaker has not tripped.
could also be the TV fuse or power supply PCB.
You should be sure to put a good surge protector in line with this TV as these constant surges are going to severely shorten the life of the unit.
Jul 24, 2014 | Televison & Video
After a power outage my tv will not turn off and the screen is completly black
With a power outage - power surge - anything is possible. One or more board s could be bad. If you have insurence you might be able to get a servicer to say that it was a surge and your insurence compaony will replace your set.
Mar 15, 2013 | RCA L32WD22 32 in. LCD HDTV
Hi, this morning we experienced power outage in our location, after 5 hours later power came back, but not our main server IBM System x32002. I checked the monitor and there is power. I check the green...
Depending on what caused the power outage, you may need to replace the power supply in the server. When outage happen and the power is restore. a power surge can destroy power supplies, especially if not connected to an UPS unit.
Good Luck
C2Solutions
Feb 17, 2011 | IBM System x3200 M2 Server
Steady blink green light, WILL NOT RESET!
Thats a common problem with that model which is the V26 chassis. The V26 DM repair kit available at www.tvrepairworld.com should repair that issue. The kit contains the replacement capacitors and the CD with detailed instructions its 35.99 which includes shipping
Oct 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My Vip622 was down this morning, no power outage,
Unplug the unit from the mains for at least an hour, then plug it back in again and try to boot it up.
Good luck
Jun 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
May 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Reset tv to factory setup
Most current TV units can be reset to default factory settings by being unplug from the mains fro at least a couple of hours (or overnight).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 19, 2008 | Televison & Video
KV-35V65 Triniton Color TV.
CRT is probably going bad... You can talk to several Techs and they'll each give you their theory on what to do about it and some will say have it rejuvenated. But in the twenty years I've been in business it's never worth the money or effort...
If you elect to do so a tech can come out to the home (for a fee) and bring with him/her a crt tester/restorer, like a BK-467. They'll attach it to the cack of the picture tube, do a few measurements for emmission and shorts, then attempt to restore it... Now that may well look like a pretty good picture when they leave and it may last you a year or two - but the down side is it may fail again in less than an hour and you're back to square one, out the money for a service-call as well.
My best advice is start shopping for a new TV and maximize your investment...
Hope this helps!
Bill
Nov 11, 2007 | Sony KV-35V65 TV
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
370 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
