Question about Briel Domus Due Espresso Machine & Coffee Maker
Spares Where can I get a new grounds basket for my Briel Due in the Uk/ Europe? Thanks, John
  • 1 more comment
  • marsar Jan 16, 2009
    I need parts for my briel I cant find anything anywhere I need a new filter basket and gaskets it leaks all over the place. For a $400 machine I cant believe no parts are available, have looked for a while no luck
    Please help!! :)
  • Bones22 Feb 03, 2009
    These people are fantastic. Mailed parts to the UK no problem & saved my machine.
    Electra-Craft. Mail them from their web site.
Try these people
I got a new basket from them for about $6
Electra-Craft, Inc 41 Woodbine Street Bergenfield, NJ 07621 201 439 1700
Posted on Jan 17, 2009
  • thomas_kittl Feb 04, 2009
    Yup they're great. Anybody found a repair manual or even an exploded diagram for the Briel?
Where can I buy spares for a gator
If you are in the UK or Europe - try http://www.wackywheelers.com/shop
Aug 25, 2011 | Peg Perego John Deere Gator HPX Ride on...
Need new reservoir
You can contact Briel direct they will supply spares but only from Portugal (I am in UK no one held spares) Email customer service Remember post costs could be high so consider replacing the Briel locally as it is obsolete and although a good entry level grinder, far better ones can be obtained and after all grind consistency is everything. If it is just the return spring see my FixYa. Address below Anabela Maia de SousaAfter Sales ServicesBriel - Industria de Electrodomesticos, S.A.Rua Sidonio Pais, 390 - Lugar do Rio4475-498 Nogueira da Maia - Portugalanabela@briel.ptwww.briel.ptTel: +351 22 961 9430Fax: +351 22 961 9435
Jul 27, 2009 | Briel CG5B Electric Burr Grinder
Briel Chamonix es35 New..
Pods are expensive. I buy espresso grind from my favorite local espresso shack and I take regular drip coffee filters and cut small discs from them to put in the bottom of the cup that holds the grounds (moisten first). It works great and keeps the finer grounds from clogging it up.
Feb 21, 2009 | Briel Chamonix ES-35 Espresso Machine
Briel Apollo no water when making espresso
Check that the water tank is seated properly. When you lower it in place just give it a little nudge down to make sure its slotted into the catch.
Nov 24, 2008 | Briel Domus Due Espresso Machine & Coffee...
Spares for Briel Coffee Machine
You can obtain any part at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Nov 12, 2008 | Briel Domus Due Espresso Machine & Coffee...
Briel Versatile Due Coffee Machine
You can get it at the Briel service/distribution center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Sep 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Coffee basket
Contact Electra-craft.com..they are in New Jersey
Jun 25, 2008 | Briel Chamonix ES-35 Espresso Machine
Espresso maker not workin properly
Your Brew Head screen and/or filter basket might be clogged with coffee oils. You can soak both pieces in a product that removes coffee oils from either www.urnex.com or Dezcal brand. Coffee shops will do this once a day. If you have the filter basket with the screw in the middle, you will need to remove the screw and soak everything as it can clog also.
If that does not work (it should tho) you can contact the Briel service center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Espresso Machine
Possibly, if it is leaking from the bottom only, and if you have a Domus Due model, you might just need a new water reservoir as the water reservoirs are a different system than all of the other briel machines and a new reservoir will usually fix the problem of leaking on the bottom in the Domus Due machines. Something with the seal on the reservoir.
You can order just a water reservoir by contacting the service center at:
Electra-Craft
41 Woodbine St
ph 201-439-1700
If your machine is leaking over the filter handle, brew head etc, that could be the coffee oils have built up in the Brew Head Screen and/or filter basket itself. For that, remove the Brew Head Screen and soak along with the Filter Basket in a coffee oil remover (not descaler) you can get the Cafiza powder at www.urnex.com or any other brand and then use a brush to clean it after soaking. If you have the Briel filter basket with a screw in the middle, please remove the screw and clean in there as it tends to get clogged. Then just be sure not to screw it too tight again as this can cause leaking.
I hope the info was helpful.
Apr 16, 2007 | Briel Domus Due Espresso Machine & Coffee...
Briel Domus Due Espresso Machine & Coffee Maker Logo
419 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
