Question about Dell OptiPlex GX520 PC Desktop
Seeking help I have changed the set up of my pc's windows xp just leaving the current system intact.but i can't access my files being at the new window.it says "access denied"what shall i do?
    Sergeant:
    Champion:
  • 334 Answers
Did you have win 98 and change to xp i don't quite understand what you've done
Posted on Nov 22, 2008
My hard drive crashed, how do I reformat a new one for this system?
You'll need the setup disk for the operating system such as XP or Vista. Format the disk in the setup when prompted to reformat or leave the current file system intact.
Nov 04, 2010 | Dell OptiPlex GX260 PC Desktop
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
1. Insert the installation disc.
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
Format
How to partition and format the hard disk using the Windows XP Setup program loadTOCNode(2, 'moreinformation'); You can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps: Step 1: Partition the hard disk loadTOCNode(3, 'moreinformation');
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 (http://support.microsoft.com/kb/314859/ ) Limited OEM driver support is available with F6 during Windows XP Setup
  4. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  5. Press F8 to accept the Windows XP Licensing Agreement.
  6. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  7. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select an existing partition, or create a new partition by selecting the non-partitioned space where you want to create a new partition. You can also press C to create a new partition using non-partitioned space.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that you want to include in the new partition. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
    If you do not want to install Windows XP, press F3 two times to exit the Windows Setup program, and then do not follow the remaining steps in this article.
    To format the partition without installing Windows XP, use a different utility.
Step 2: Format the hard disk and install Windows XP loadTOCNode(3, 'moreinformation');
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  2. Select the format option that you want to use to format the partition. You can select from the following options:
    • Format the partition by using the NTFS file system (Quick)
    • Format the partition by using the FAT file system (Quick)
    • Leave the current file system intact (no changes)
    Notes
    • If the selected partition is a new partition, the option to leave the current file system intact is not available.
    • If the selected partition is larger than 32 gigabytes (GB), the FAT file system option is not available.
    • If the selected partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm).
    • If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    • If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you are prompted to select a file system for both the System and Startup partitions.
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions. For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base: 309000 (http://support.microsoft.com/kb/309000/ ) How to use Disk Management to configure basic disks in Windows XP
Tanks. Cheer!
Mar 23, 2010 | Computers & Internet
Screen is black, whenever i save any wallpaper, it is not seen once it is restarted after shutting down. gets a message "you may be a victim of software contrefeiting " and "the copy of windows did not pas...
oh, theres the problem... your software (windows xp) is pirated or counterfeit version... try reinstalling with a GENUINE microsoft windows xp, that should be fine,, you can reinstall os without the need of erasing all your documents, just choose >>LEAVE CURRENT FILES SYTEM INTACT(NOCHANGES) when prompted at the setup screen..
Nov 29, 2009 | Microsoft Windows XP Professional With...
How to install xp in HP Pavilion dv6 1030 us Laptop and how to repartition my C: drive especially I have still 150 GB free space in C drive Please help me in this case Thanks in advance.
get a winxp installer CD, you can repartition your drive on the first part of the winxp installation process. Prepare your drivers for your machine especially the network and USB drivers which you will need to copy and transfer files firstly.
If u meant of installing an additional OS like winxp to your extra space, you need a boot loader to switch between OSes.hope this helps
Aug 17, 2009 | HP Pavilion dv6-1030us Notebook
CANNOT BOOT WINDOWS XP ON MY ACER ASPIRE ONE LAPTOP
hi..if u have a Windows XP installer just put in the CD/DVD player then auto run the win XP and make install the new windows/OS and make a choice leave the current files if you to re cover the files using a new install OS/Windows..Good Luck and Have a Nice Day...
Jun 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
What are the steps and files to activate F11 recovery system????
typically your XP system has a restore for settings which is a program in windows.
F11 on boot is a type of recovery that bassically recovers your windows unless it specifies otherwise or is part of the system Bios.
It usually recovers from your install disk and restores your windows and leaves the personal files intact. This is if you accidently damage some windows files through tinkering and what not. Relying on the laptop as a back up is not a good idea because everything is on one Hard drive and if that goes, then your stuck.
Your better off getting an External Hard drive and connecting it, backing up all your personal files to it, and then leaving it stored in a safe place in case something bad happens.
There is also a way to use the windows CD to restore the windows files from the Windows installer when booting from CD which restores all the OS files and leave the personal files intact. Allthoug it does reset all the windwos prefferences.
As for ths F11, I have that option as well and fine it not to be reliable.
Hope this helps point you in the right direction.
Feb 16, 2009 | IBM ThinkPad R31 2656 Notebook
HDD Partition help
Important If you follow these steps on a hard disk that is not empty, all the data on that hard disk is permanently deleted. We recommend that you back up your hard disk before you follow these steps.
To partition and format your hard disk by using the Windows XP Setup program:
1. Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer.
Note To start your computer from the Windows XP CD-ROM (or from the startup disk), your computer must be configured to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive, see the documentation that is included with your computer, or contact the computer manufacturer.
2. If you are starting the computer from the Windows XP CD-ROM, select any options that are required to start the computer from the CD-ROM drive if you are prompted to do this.
Note If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver.
For additional information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base:
314859 Limited OEM driver support is available with F6 during Windows XP Setup If you are starting from the Windows XP Setup disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after you insert each disk.
3. At the Welcome to Setup page, press ENTER.
4. Press F8 to accept the Windows XP Licensing Agreement.
5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
6. All the existing partitions and the unpartitioned spaces are listed for each physical hard disk. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition by using unpartitioned space. If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each of the existing partitions that you want to use for the new partition. When all the partitions are deleted, select the remaining unpartitioned space, and then press C to create the new partition.
7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
8. Repeat Steps 4 and 5 to create additional partitions if you want them.
9. If you want to install Windows XP, use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER. If you do not want to format the partition and install Windows XP, press F3 two times to quit the Windows Setup program, and then do not follow the remaining steps. In this case, you must use a different utility to format the partition.
10. Select the format option that you want to use for the partition, and then press ENTER. You have the following options:
The option to leave the current file system intact is not available if the selected partition is a new partition. The FAT file system option is not available if the selected partition is more than 32 gigabytes (GB). If the partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm). If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
Note If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you will be prompted to select a file system for both the System and startup partitions. 11. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue. After the Windows Setup program is completed, you can use the Disk Management tools in Windows XP to create or format more partitions.
Oct 19, 2008 | Computers & Internet
Not able to restore my registry settings...
try re-installing windows over the top of your existing operating system.
If you get a prompt during setup, stating that you already have files. tick leave intact. or similar.
this can sometimes remedy faults, as windows will only replace missing-deleted or corrupt files on the hard drive.
Your other option, is to obtain disk partioning software and setup a seperate partion on the drive, install the operating system here, so that you can access the first partion.
just out of curiosity, did you go to Tools/folder options/View and tick the show hidden files And Folders checkbox ?
Mike @ Compurepair.
Feb 22, 2008 | Microsoft Windows XP Professional
Removal of incomplete, unwanted os setup
Hey sorry about your pc sir..
OK first let me explain to you the problem you are having and the various ways we can solve it ..
ok the reason some of the files were removed is cause they were infected..
The cd you have is windows Xp, but during windows updates you updated with service pack 2, so obiously the system will ask for windpws xp cd with service pack 2,, (MICROSOFT BUGS :( )
now you have a mbr with 2 operating systems. cause the main mbr is non functionaly a secondary oe was created leaving your current file system intact, but with the bad effects of having 2 operating systems on the same partation.. hence slow sloppy behaviour..
we can remove boot sector and rewrite mbr to remove the bad operating system but that would not help the speed..
Here is what i believe is your best solution and the one i recommend..
1.) BURN all your important data to a dvd or cd so you wont loose it
2.) Boot off the the windows xp cd.
3.) delete the entire partation and format the drive(full format)
4.) reinstall windows and drivers and software..
NB.. when windows ask if you want to repair select no and install a fres copy,, when it ask if you want to leve the file system intact say no, delete the partation, and it will say unpartationed space, hit enter there and select full format..
Jan 14, 2008 | Microsoft Windows XP Professional With...
Dell OptiPlex GX520 PC Desktop Logo
29 people viewed this question
Alun Cox
