Question about RCA CC-432 Camcorder
I can't play back a tape in my camcorder.
It just won't play...
    Master:
  • 473 Answers
For Models: CC6384, CC6394, CC9373. Check to see if DSC is selected. If so, you won't be able to play a tape. Press REFRESH for about one second to select VIDEO. On the CC9373, make sure the DSC/VIDEO switch is set to VIDEO.
Posted on Sep 06, 2005
SOURCE:
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
Dec 31, 2014 | Sony Handycam DCR-TRV130 Digital Camcorder
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
How i can watch the tape from dcr-tvr27 with out the camera
of course you need that as a player, or else you have other player capable to play that kind of tape.
Mar 22, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
8mm analogue camcorder tape playback at double speed
If you ran it through that many 8mm players, I'm going to say that the tape has something wrong with it.
You can see visually if there is anything wrong with the tape by releasing the cover by moving the tape and visually inspect the tape for anything that could be frayed. Usually you can see it on the bottom of the tape.
Sometimes the takeup can be messed up in the tape too. Once you release the tape cover, you can turn the white wheels to see if there is any slack in them.
Good luck on that.
Jun 10, 2008 | Video Cameras
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
Transferring camcorder tapes to VHS
It depends on what speed these tapes were first recorded on. Maybe the camcorder your trying to use to play them back do not support this tape speed I have seen this in the past. Are these 8-MM or VHS-C tapes.. Also the tapes that were recored, maybe tyhere was something wrong with the tape path and was slightly out of alighnment. I had once a Sony 8-MM camcorder and tapes a lot of stuff and then gave them to someone to watch and they would not play. I tryed the tapes again in my camcorder and they worked great. I got a test tape and tryed it in my camcorder and it turned out the tape path alighnment was off, so i had to rerecord everything I had from one camcorder to DVD so i could fix my camcorder. Good Luck
Mar 26, 2007 | Hitachi VME545 Camcorder
RCA CC-432 Camcorder Logo
51 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
