Question about Brother MFC 210C All-In-One InkJet Printer
Brother mfc-210c keeps blingking when i press any keys and keep on saying PLEASE WAIT...
Please help me with my very big problem i have brother mfc-210c and one time when i turn it on its keeps blingking all buttons the coppy button, fax button, scan button, the photo capture button, and everytime i press any keys its always says please wait...but it cannot load to its normal LCD screen..i dont know what happen to my brother mfc-210c fax/printer...i always try to unplug the power cable hoping that it refresh its own memory to load in normal way but still its keeps blinking evertime i turn it on! please help me with this problem! thankx
  • Brother Master
  • 7,993 Answers
Here is a link to the user's manual. You should read the chapter about troubleshooting and maintenance.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc210c_all&type2=5&flang=English&dlid=
On the same site you can read the FAQs
Hope it helps.
Posted on Aug 30, 2009
MFC-210C, keeps saying " NO Cartridge" lift
This unit has issues with the ink detect sensors. Have you tried a brand new cartridge? Other wise you may need a technician to solve the issue directly.
Jun 26, 2011 | Brother MFC 210C All-In-One InkJet Printer
Mfc 210c
If you are certain that you have removed all paper, try power-cycling your printer. Remove power cord and wait a minute or two then plug back in.
Jan 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C All-In-One InkJet Printer ERROR 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds.
This should put you in the maintenance mode menu.
Enter 80, then scroll down with the arrow down (round) key.
You'll find an entry listed as purge count.
If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then restart you printer.
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
Hi, I have a Brother MFC-210C that keeps telling me its unable to clean, I followed the user manual but it keeps displying the same message, what do I do now? please help
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Dec 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Replaced ink
unplug from power outlet. wait 5 min. take ALL carts out. leave scanner top open. replug to power. wait til machine demands carts. insert carts. close cover. answer display question.
Do make a firmware update. download small tool from brother homepage of your country!
Mar 12, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210 Printer Trouble
unplug for at least 20 minutes, then disconnect all the cables from the printer, plug power cable back in and turn back on
what happens?
look in your manual, is there anything to set back to factory default? if so do this if the first steps don't work
Jan 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC-210C ALL IN ONE
The problem is your need to change the Main board or scanner...cant be fix it need be replace either main board or scanner sometime worse senario it need both.....The cos of teh scanner and board kinda expensive....
Dec 15, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C stuck in "please wait maintenance"
Press menu then start mono (b/w) then 4x arrow-up-button. Machine will be in maintenance-mode: What error code does the display show off?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
232 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
