Question about Whirlpool Refrigerators
Our whirlpool american style fridge frezzer has not functioned properly since purchase the fridge constantly is warm
    Genius:
  • 2,920 Answers
It should be under some sort of warranty call and find out and if so the repair that would need to be done should be free
Posted on Aug 27, 2008
Have purchased a westinghouse aurora double door fridge frezzer second hand in the middle off doors its very warm and the fridge side doesnt seem to be as cold as it should be. Frezzer side fine any...
There is a heating coil in those for defrosting purposes. You need to check and see if there is a defrost timer and see if it is stuck. Since you did not post the make and model number, that is as far as I can advise
Oct 27, 2017 | Westinghouse Refrigerators
Whirlpool American fridge freezer side by side freezer is fine but fridge is freezing.
there is a control inside for the fridge that might just need turned down to a lower number called air damper they fail sometimes and sometimes we put too much stuff in front of the vent so they can not function properly .
Feb 29, 2016 | Whirlpool Refrigerators
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Where can i find the model number on my whirlpool fridge freezer, American style?
open fridge door and pull out second from bottom draw - the sticker is on the righthand side
Jan 03, 2011 | Whirlpool Refrigerators
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Samsung SR-S2028DVW american style FF keeps defrosting
I would suspect the thermostat or the defrost timer is malfunctioning.
Jul 18, 2017 | Samsung Refrigerators
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flickering display panel on Whirlpool american style fridge/freezer
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
Jul 16, 2008 | Whirlpool Refrigerators
Frezzer working fine, but fridge very warm what do i do
if the technician says you need a defrost heater, then it should be replace for the refigerator to work perfectly.
Jun 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
