Question about HP OfficeJet 7410 All-In-One InkJet Printer
Scanner Error Power Turn off than on
When I turned on Office jet 7413, the display screen is giving error "Scanner Error Power Turn off than on"
plz Assist me to slove this issue.
  • 72 Answers
If you are get that error message than unplug the power cord, and than press Poun and Number 6 Keys together on the keypab of the printer. While these keys are pressed and hold, than at the same time plugged in the power cord and dont release the two buttons.
After say 30 second you will get a new message on the screen of the printer.
All of the above steps actually reset the printer. I hope this will work.
Regards,
Lalit
Posted on Sep 09, 2008
Konica Minolta biz 600 error c-6708 plz help
exposure lamp or CCD issue. both located under the big glass. The CCD is the large black device on the right. The scanner is device on left that lights up scan a document though the Doc feeder or main glass.
try this reset
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the destroy the lamp or CCD
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
Apr 21, 2017 | Konica Minolta Office Equipment & Supplies
How to solve scanner error 22 in HP laser jet 1213mfp
Perform a power reset.
Press the Power button to turn on the printer.
With the printer turned on , disconnect the power cord from the rear of the printer.
Wait at least 30 seconds. Reconnect the power cord to the rear of the printer.
update the firmware by download from this link: HP LaserJet Pro M1213nf Multifunction Printer Drivers
Jan 20, 2015 | HP Office Equipment & Supplies
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner Error 6 Turn Off Then On
Dear Sir,
Welcome to Fixya
1.Switch off the printer, then remove all cables connecting to the printer but just the power cable.
2.Then press and hold the *(start/symoble) and 5 button togather and turn on the printer,continue holding the button till you see "perment storage init" displayed and release the button.
3.Then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required.
I think it deffinately helps.If you have any problem regarding this issue leave a feedback we were happy to assist you
Have a Nice Day!
Oct 03, 2009 | HP LaserJet 3055 All-In-One Printer
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Sep 23, 2009 | HP LaserJet 3030 All-In-One Printer
I keep getting a scanner failure error
Let's try this. Turn power off, unplug the cord from the surge strip or wall socket. Leave unplugged for about 30 minutes, then plug back in and turn on. Hopefully this will fix your problem. Good luck.
Mar 19, 2009 | HP OfficeJet 7130 All-In-One Printer
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Scanner Problem HP 1005
for resolve this error you should only change the flatbed scanner wiht a new one. this error is hardwere issue.
by.
M.R.Atyabi
Dec 29, 2008 | HP LaserJet M1005 Printer
Error code: 0xc52004 411:lib_micci2.0
This is your solution: s.gif s.gif
Issue The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
May 29, 2008 | HP PSC 1610 All-In-One Printer, Scanner...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
