Question about NAD Audio Players & Recorders
I have a problem with NAD 3300 moniter series its power output tranisters damaged i replaced one by one . now there is no sound at the colector of Q51 or q 52 and the voltage is also 4v
  • 4,234 Answers
Normally the outputs are changed in pairs because the failure of one tends to stress the other enough to make it the next failure. I don't have the service manual so I can't tell what Q51 or Q52 are, but when the outputs go bad (shorted usually), you must also check the driver circuit and the bias transistors. It is very unusual for only the outputs to be bad. Check all of the resistors in the area as well. Low valued ones may be open and since the are often flameproof resistors, there will be no physical indication that they are bad.
Keep us posted.
Dan
Posted on Aug 27, 2008
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
NAD C350, everything works after i replaced many blown parts except it has no sound output from any channel, just need some ideas on what to check for faults. thanks
With no background on the original problem and no details regarding what parts were replaced how can anyone answer the question?
What exactly does it mean if 'everything works' but it has 'no sound output'? As a two channel amp that would be its ONLY function.
The root cause for 'no sound' could be something as simple as a misplaced control (Tape Monitor?) or missing pre-out/main in links. It's in the manual.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/NAD-C350-Amps-manual/id/8043dj589/t/2/
Jun 01, 2011 | NAD C350 2-Channel Amplifier
I have an NAD 7250PE. I get no sound out of the speakers and no sound out of the headphone jack BUT the inputs and tape out work. Anyone have ideas on what might be the problem?
The final output stage of the amplifier section is not working. This can be cased by a power supply problem or defective output transistors to name a few possibilities. Without seeing the actua unit and taking a few measurements inside, I can't say for sure. These are decent units and have fairly common output designs. Expet a parts cost up to $50 or so for this repair. (It can be less if just the power supply area)
Dan
Apr 26, 2011 | NAD C720BEE Receiver
How do you connect a nad c270 amp to the bose 901 series vi equlizer and system/
Bear in mind that 901's require exclusive use of any amplifier they use. You shouldn't expect to use conventional speakers alongside them on the same amp. The reason is that the 901's require the use of their dedicated Active Equalizer to shape the frequency spectrun to match their drivers' response curves, resulting in a flat sound output. Applying that kind of equalization to any conventional speakers will sound to sharp at the extremes and may even potentially damage them.
For connection I would run a pair of RCA cables from the L&R Audio Line OUT of whatever preamp or source you're using to the Active EQ's Line IN; then the EQ's Line OUT to a NAD amp's Line IN. DEselect any Tape options on the Active EQ, attach the 901's to the new amp, set the NAD volume controls pretty high (and leave them alone), run through any level setup procedures in your control electronics for volume, etc and you're done.
Aug 17, 2010 | NAD C270 2-Channel Amplifier
Screen does not light up
Hi
disconnect the power cable and remove the battery nad then press nad hold the power button for a minute. then connect every thing back and then see if the screen comes on.
in case it does not then again remove the battery nad power cable and remove the hard drive nad ram and put it back in again.
nad then check still does not work see if the screen comes on an external moniter, still if it does not come on call HP if it is under warrnty they would give you free repair.
Apr 12, 2010 | HP Pavilion dv2000t Notebook
Nad c270 power amp transfomer hum
if the hum is in the sound output you have a blown power regulator
Mar 31, 2010 | NAD C270 2-Channel Amplifier
I am trying to hook up my home theater system
marvidson,
With the NAD model that you have and its lack of component or HMDI switching, the only way is to connect your system, sort of, backwards.
The only way to do it is to connect your digital cable box and blueray player directly to the tv, then the audio output from the tv to one of the video inputs on the NAD. The NAD has digital coaxial and toslink inputs so if your tv has one of them as an output, that would give you the best sound to the NAD. If your tv does not have either of those outputs, then you will be limited to the composite outputs (red and white) but that will still give you good sound.
Also, depending on the digital output to input configuration, you could possible find a converter online.
-Chris
Jan 19, 2010 | NAD T751 Receiver
Nad 310 no power
The output should be 24v ac. Sounds like you have a busted transformer. Did you check out the resistor in front of the transformer.
You sound like you know what your talking about so I will not bore you with suff like glass fuses and thermal couples.
Good luck, I have had a few items like this over the years. Sometimes it's just best to send them in to the manufacture. I would look for a replacement transformer. 120v ac to 24v ac around 5 amps. Test it out and see if it works... If not, send it in.
Jan 22, 2009 | NAD C320 2-Channel Amplifier
NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Apr 29, 2008 | NAD C350 2-Channel Amplifier
122 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
