Question about RCA CC-432 Camcorder
Can't access all the menus...
Some menus or features on my camcorder are not available.
I NEED A MANUEL FOR THE CAMCORDER
Posted on Sep 01, 2008
    Master:
  • 473 Answers
Some RCA camcorders feature both Automatic and Manual recording modes. Some features on these camcorders are only available in Manual mode. Check to make sure the POWER switch is set to M, and not A, then try again. If you are unsure of the recording model features of your camcorder, refer to the owner's manual or the product catalog on the website. Look on the bottom of your camcorder to locate the model number.
Posted on Sep 06, 2005
Cm6040 unlock menu
Navigate the Administration menu
From the Home screen, touch Administration to open the menu structure. You might need to scroll to
the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch
the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains
sub-menus. Continue opening the structure until you reach the option that you want to configure. To
return to the previous level, touch Back.
To exit the Administration menu, touch the Home button in the upper-left corner of the screen.
The device has built-in Help that explains each of the features that are available through the menus.
Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help
system, touch the Help button in the upper-right corner of the screen.
The tables in the sections that follow indicate the overall structure of each menu under the Administration
menu
Aug 13, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
My spart LG remote (AKB732955) will only turn tv off/on and control volume. How do I get it to interact with the available menus?
It only does those features. You need to use the original remote to access menus. Your original remote is the AKB72914042 remote control.
Nov 29, 2012 | Televison & Video
I need a usrs manual
The manual is available at Hitachi Support: http://www.hitachiserviceusa.com:8080/Index.aspx . Use the drop down menus to choose DVD/Blu-ray or HDD camcorders and then your DZBX35A.
I hope this helps.
Feb 24, 2011 | Hitachi DZBX35A DVD Camcorder
I have a 2010 Buick La Crosse CXL and when trying to set the memory for the seats and outside mirrors I can only get the seats to retain the memory. When I place the car in drive the mirrors go down out...
this might be what you're experiencing.......
Park Tilt Mirrors
If the vehicle has the memory
package, the outside mirrors
have a park tilt feature. This feature
automatically tilts the outside
mirrors to a preselected position
when the vehicle is in R (Reverse).
This allows the driver to view the
curb for parallel parking.
The passenger and driver mirrors
return to their original position
when the vehicle is shifted out of
R (Reverse), or the ignition is turned
off or to OFF/LOCK.
This feature can be turned on or
off through the Driver Information
Center (DIC)
The audio system controls are used
to access the personalization
menus for customizing vehicle
features. (DIC)
CONFIG (Configuration):
Press
to access the Configuration
Settings Menu.
MENU / SELECT Knob:
Press the
center of this knob to enter the
menus and select menu items.
Turn the knob to scroll through the
menus.
0
BACK:
Press to exit or move
backwards in a menu.
Sure hope this helps!
Best to you.
Mar 06, 2018 | Buick LaCrosse Cars & Trucks
Need codes to access TV menus
The solution relies with the remote. press the menu button and use the +/- buttons beside it instead of the volume or channel buttons. This TV was at a work camp in northern Alberta and the instructions were not available. Hope this helps others who do not have instructions available.
Apr 18, 2009 | Toshiba 13A25 13" TV
Hour glass pops up and doesnt go away. i cant use ant features and cant access any menus any help?
Sounds like a bunch of malware in your system. See if you can use your system in "safe mode" - F8 key when booting up. If you can, reboot back to normal startup and try a free malware program. Malwarebytes.org is currently one of the best.
Feb 19, 2009 | JVC GZ-HD3 HDD HD Camcorder - 60 GB USB...
RCA XS J25330BL cannot access full setup menu
Your best solution is to get rid of that crappy TV! Having an old tube Tv really makes the rooms look bad.
Sep 02, 2008 | Televison & Video
Should I use automatic or manual while recording?
Select RCA camcorders feature both an Automatic and a Manual recording mode. Automatic recording places the camcorder into Auto Shot™ mode. Focus, exposure, iris control, white balance, and the video light are controlled by the camcorder during Automatic recording. This mode is particularly handy for those times when you want to be able to just point the camera and record. The Manual recording mode allows you to control many of the elements above yourself, as well as many of the camcorder's special features including Animation and Time Lapse. Manual mode is also where you access the menus and set the clock. Make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode.
Sep 06, 2005 | RCA CC-432 Camcorder
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shot™ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
Do the DVD-Cams have any editing functions?
Yes: Delete, Play List, Move, Divide, Combine and Fade are available when recording onto DVD-RAM discs. This feature is available by utilizing HITACHI’s Disc Navigation System. DVD-R discs cannot be edited.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
RCA CC-432 Camcorder Logo
135 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
