Question about Xerox Office Equipment & Supplies
Faxes are covered in bubbles - Xerox Office Equipment & Supplies
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Xerox Master
  • 1,362 Answers
Sounds like the fuser unit is shot (exit where the ink gets fused into paper)
Posted on Aug 27, 2008
My 2001 polo When iddling I noticed oil on spark plug no.1. upon inspection when I rev it there are air bubbles around the spark plug. What could be the cause of this? Tarpet cover is not leaking.
Bubbles round the spark plug could mean that the plugs need retightening. Not necessarily connected to the bubbles issue but you could be advised to check and regap the plugs. How old are the plugs?
May 06, 2015 | Cars & Trucks
PAINT BUBBLING ON RHS ENGINE SIDE COVER
if its bubbling and white powder coming out its corrosion and you need to get a drill with a wire brush and a small sander disc to remove the bubbles then primer then paint ! if the paint has bubbled and slight brown discolouring its your engine overheating and needs checking why ! P...
Dec 03, 2013 | 2001 BMW F 650 GS
I am looking to buy a Mercedes GL 500, model 2009. One of checks a friend of mine does before buying a second hand car is to start the engine and then open the hood and remove the oil cap, according to him...
oil bubbles ? oil splashes under valve covers across the valve train opening the valve cap may get oil splash-- but oil bubbles oil may foam a bit from being old or if coolant got in it and wouldnt bubble out of cap but bubbles --- and oil splash is normal when opening oil cap with vehicle running
Sep 10, 2017 | 2009 Mercedes-Benz GL 500
Faxes being sent with major streaks
Open the cover where the documents are loaded and clean the thin glass there. It may have some white out or dirt on it.
Jan 20, 2012 | HP 640 Inkjet Fax Machine
Does the solar cover need to have buttons up or down?
Solar pool covers should always be installed with the bubble side down, touching the water.
Jul 16, 2011 | Midwest 8 Mil 25' X 45' Rectangular Blue...
I have a pentair minimax nt high altitude propane 4000000 btu in a commercial setting i run it 12 hrs a day is that too much?
Hope you are using lots of insulation. I have a bubble cover exposed during sunny days then put pool cover over at nite. Also have 4 x 8 ft Styrofoam pink insulation on top of the bubble cover. That costs $19 per sheet at Home Depot. 2" thick R 10.
Nov 07, 2010 | Pentair Minimax NT Heater
Hello our Muratec F-320 will print faxes with a
lIFT THE BLACK PLASTIC COVER ON TOP OF THE TONER AND DRUM CARTRIDGES. UNDERNEATH THE COVER CLEAN THE ROW OF "EYES" RUNNING FRONT TO BACK. SHOULD FIX IT...PROBABLY HAVE SOME TONER ON THE GLASS EYES.
Jun 24, 2010 | Muratec F-300 Fax
"unable to clean"
Hi dbostrander.
First check for foreign objects in the paper path. Check if you have any faxes in memory because you will lose them when removing power; see later.
Pull out the paper tray from the front and check for paper jams or torn paper anywhere inside the machine. Also check the 'jam clear screen' at the back of the printer. Remove the cover, remove any obstacle then replace ther cover.From the front of the machine lift the top cover from the right side till it is fully open on the slide. Check for jams. If the jam is under the print head you will have to disconnect the power (losing any faxes in memory *see below) to move the print head out of the way to clear the jam.Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Check whether the MFC has faxes in
memory
1.Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
and then reconnect it then do as above.
—OR—
If faxes are present, you can transfer them to
another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3.Enter the fax number to which faxes will be
forwarded.
4.Press Mono Start.
5.After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,0, 2 in step 1.
Hope this helps,
Mark.
Mar 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
19 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
