Question about Epson LQ-2180 Dot Matrix Printer
Pause light is on continuosly. Even if you switch off and on it remains on. what could be the problem?
Check the cover sensor at the right side of the printer..
Posted on Oct 14, 2008
Hi, i have a 2003 mazda6. my alternator went bad and i accidentally took off the positive battery pole off the battery. this caused an overcharge in the system which caused 1. all my indicator bulbs to...
my alternator just died on me, I have disconnected the negative battery terminal, took off the right wheel and shrouds, removed the alternator's upper and lower mounting bolts, but there is one on the side of the electrical connection that is hard to reach, is there any suggestions.....I have a 2003 Mazda 6
Mar 03, 2011 | 2006 Mazda 6
Brake lights continuosly on even when car turned off and has drained battery is the sensor jammed on and if so where is it to fix problem hyundai excel hatchback 1997 model
there is a brake light switch on your brake pedal it seems very well that it is stuck on look under dash at brake pedal arm you will see a switch with wires to it push pedal down and see if switch releses if not you need a new one
Dec 29, 2010 | Hyundai Excel Cars & Trucks
My Samsung cdma SCH-F699 is not getting switched on .Only the model number is getting displayed.What should I do
my samsung sch-f699 is not getting started it only displays the model number and continuosly remains displayed so what should i do?
Dec 12, 2010 | Samsung Cell Phones
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Red light blinking
You have a bad main board most likely. You can try unpluging it for 5 minutes.
Sep 03, 2009 | Philips 42PF9631D 42 in. Plasma Television
Yesterday i bought a 1989 900i SAAB. Fab car, BUT!!!!
this might help... go to this webpage... there is a picture of the switch.... http://www.autopartswarehouse.com/details/QQSaabQQ900QQScan-TechQQHeadlight_SwitchQQ19821998QQW0133-1610845.html
did you happen to buy that in canberra ?
Apr 16, 2009 | 1993 Saab 900
I have a schaerer opal coffee machine, when I switch the machine on, the water light flashes, and a pump runs continuosly as if it is trying to purge the machine. but nothing comes through. does anyone...
I have a schaerer opal coffee machine, when I switch main power machine on, the descaling indicator, cleaning/rinse indicator and stand-by mode indicator lamp remains lit, and a pump runs continuosly. the machine do not ready mode indicator. Yudi INDONESIA
Apr 05, 2009 | Schaerer Opal Espresso Machine
1993 Corolla. Brake lights remain on, even with
Definately the brake light switch,locatedabove the brake pedal (may need to drop the lower facia panel) switch may need replacing or more than likely adjusting. new switch about £10. Good luck Davelee
Mar 23, 2009 | 2003 Toyota Corolla
Printing Speed
what interface are you using? sounds like windows is sending the data to the printer as graphics which is much more intence then EPL hence the delay between each label.
Mar 02, 2007 | Zebra Eltron TLP 2742 Thermal Label...
Epson LQ-2180 Dot Matrix Printer Logo
846 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
