Question about RCA CC-432 Camcorder
How do I clean the camera?
On my camcorder, the viewfinder, LCD monitor, and the lens are dirty and need to be cleaned.
    Master:
  • 473 Answers
Gently wipe any glass surface on your camcorder with a soft, lint-free cloth. Wipe the LCD monitor in a semicircle to avoid spreading a stain. Check the edges of the lens for loose particles. Caution: Do not touch the lens with your fingers. The oil from your skin can damage the lens.
Posted on Sep 06, 2005
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
No signal, only blue lcd-monitor, when playing my footage, yesterday it was ok. also trouble with recording
Did you try resetting the camera by turning it off, taking out the battery and removing any other source of power? Try this first to hard reset the camera.
Does the optical viewfinder function or is it also blue?
Hopefully hard resetting will solve your problem but if not then there may be an electronics fault in your camera.
Jun 24, 2008 | Sony Handycam DCR-TRV900E Mini DV Digital...
Looking through viewfinder i see dirt & black specks
It depends where the dirt is. Following the light path, look at the rear surface of the lens. A dirty rear lens surface will have the most affect on picture quality or what you see in the viewfinder of any position in the light path. Like all optical cleaning procedures, hold the lens with the rear lens surface facing the ground so gravity will work with you. Start by blowing clean air on it using canned air or a blower such as a Rocket blower or ear syringe. If that is sufficient, do not continue the sequence. This holds true at the conclusion of each step because the more aggressive your cleaning becomes, the more risk there is of damage. If it is still dirty, gently brush it with a sable or camel hair brush. If that is not sufficient, gently wipe it with a dry lens photograph lens tissue (do not use coated tissues) or a microfiber cloth. Finally, as a last resort, dampen a corner of a lens tissue or microfiber cloth (do not put the wet solution directly on the lens) and gently wipe with a circular motion. Finish by wiping with a dry section of the tissue or cloth. Although the front surface of the lens is not as important, repeat the process for the front surface.
If you still see the dirt in the viewfinder, are two possible remaining locations; the bottom surface of the prism located above the mirror or the mirror.
Clean the prism first and avoid cleaning the mirror if possible, or any contact with the mirror. The prism can be cleaned following the sequence outlined above. If that doesn't work, the problem is the mirror.
CAUTION! The mirror is front surfaced and is very susceptible to scratches and other damage unlike a conventional mirror which is rear surfaced with the glass protecting the coating. Aggressive cleaning should be avoided.
Carefully follow step 1 of the lens cleaning procedure (air) and step 2 (brushing) if necessary. As far as the third and fourth steps, I would not use them myself because of the risk of mirror coating damage. It would be better to take your camera to a qualified repairman.
remove the lens and look above the mirror at the bottom of the viewfinder prism. If it is dirty, clean it as you would clean a lens surface. The next place to look is the mirror.
CAUTION! The mirror, unlike the mirror over your bathroom sink, is front surfaced and there is no glass between you and the delicate and easily damaged coating. Hold the camera with the mirror facing down so that gravity will work in your favor. If that does not work, I would stop and take it to a camera repairman because you do not want to risk scratching the surface by using lens tissue or cleaner.
Feb 05, 2013 | Nikon F100 35mm SLR Camera
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
Leans moror cleaning
Your camera doesn't have a mirror it uses an electronic viewfinder/LCD, also the lens is fixed so without complete dismantling of the camera the sensor can not be cleaned as with a "conventional" DSLR. I'm going to suggest if you feel the sensor requires cleaning I'd look at the front lens element and clean this with a lens cloth, the LCD screen can be cleaned with a lens cloth as well use a cloth not tissue.
Jan 14, 2011 | Fuji FinePix S7000 Digital Camera
Picture is not clear in the viewfinder
This can occur from many different things. First of all, it is possible that your lens is dirty, try cleaning it while taking the proper precautions. Also it is possible that some cameras have a setting to reduce the pixel quality in the viewfinder to reduce battery consumption. It might be adjustable in your settings. Hope this helps.
May 24, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Thick dark vertical lines appear on the video taken during playback.
It is problem of dirty / clogged video heads, use good quality video head cleaner in your camera and clean video head. Problem will be resolved.
Nov 10, 2008 | JVC GR-D250 Mini DV Digital Camcorder
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
No display in viewfinder and LCD
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
May 07, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
RCA CC-432 Camcorder Logo
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
