Question about Sharp R-1480 Microwave Oven
EE3 present error EE3 in display.
  • Anonymous Mar 22, 2014
    ee1 and ee3 and ee5 brand new
  • Sharp Master
  • 9,086 Answers
Is your model number something like R22 or R24?
If so, "EE3" is "Magnetron (1) and (2) failure".
Most commonly this is caused by a bad door switch or door switch mount or a bad connection or bad relay on the circuit board.
We have a service manual for these models and have uploaded it to our site here to help you.
You will need the free Adobe Reader to view or print it.
Please reply back with your model number if you need more help.
Posted on Sep 01, 2008
Why does my microwave not work? It displays what I believe is an error code.
. The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
-korrinA S
Mar 03, 2015 | Kenmore Microwave Ovens
How do I replace the bulb for the display panel of a Sharp Microwave oven Model # R-314F ?
Normally switch power off and remove plug from wall socket, undo screws around side and back panel and remove outer cover, then the light socket will be visable so change light bulb and reassemble, CAUTION: high voltage may be present so best left to service person for safety
Jul 23, 2014 | Sharp Microwave Ovens
Call service error
There is a fault in the magnetron circuit somewhere. Do not mess with this yourself because there is lethal high voltage present even when the microwave is unplugged. Call a service tech.
May 23, 2014 | Amana Microwave Ovens
Whirlpool GH6177XPS3 Touch Error display
I've got the same problem and error code. Did you ever find the fix?
Jul 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Hi, I have a Sharps R-23 AM 1900W microwave. When i use it, it starts the timer and counts down for a few seconds then stops and flashes with 'err 3' on the display. Can you help at all with...
Is that code actually "EE3"?
If so, that is called a Magnetron (1) and (2) failure, but it may not be the magnetron.
It may be any of number of things, form door switches to control board relays to the high voltage parts.
Methodical troubleshooting is needed, and we have the manual for similar models here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | Sharp Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Power but no display to unit
Not sure about the Neff brand, but in general you'd want to check for 110VAC power on the primary side of the low voltage transformer on the control panel / board. If that is present, check the secondary for voltage, about 12-30VAC. If the unit has a VFD type display, there will be a heater filament supply, usually around 2.5-6VAC. Also look for bad connecitons on the VFD. If those voltages are present, check connections on the board, look for bloated / bulging capacitors, shorted diodes, breaks in the board, etc. Also look for thermal cutouts and thermostats. If this doesn't fix it, can you take several photos of the inner parts and circuit boards?
Sep 26, 2006 | Neff H7871A2GB 800 Watts Convection /...
Sharp R-1480 Microwave Oven Logo
291 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
