Question about Nilfisk Vacuums
Nilfisk GM 90 motor bearing Hi I have replaced the motor bearing on the GM 90 model but having problem with re fitting the turbyne I forgot the sequence it has 2 turbines and 4 2 inch washers Can you please tell me the sequence it is fitted Thanks,,,Ps the motor is 100% ok now Peter
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Looking for Replacement Motor for Bosch Ultra 1450W Canister Vacuum
If you are finding BB's. then the bearings are bad. You could pull the motor and take it to a place that rebuilds motors to see about replacing the bearings. If it is a Lamb or amtec motor, there is a number stamped on it, you can match up another motor with that number. Go to a place that sells Vacuum repair parts and they maybe able to get you a new motor.
Posted on Jan 16, 2008
SOURCE: When vacuuming dust does not go into bag but goes all over the place.
Used an elastic band to tighten bag onto nozzel.
Posted on Sep 28, 2008
VacuumRepair
  • 438 Answers
SOURCE: I have a kenmore canister model number
Greetings from GoVcauum.com,
Ok, so good news, I have looked up your model number for your Kenmore vacuum and found that your Kenhmore canister takes the motor AC92FAUX2000.
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357
#13 on diagram Image not available Motor Number: 4147248 Substitution: 705357In stock
You may buy this part from the link to GoVacuum.com above. I have personally gone back and checked this motor, and it does have 4 wires that come off the motor itself.
I also verified this by pulling up your parts diagram for your model, and it did call this part number as well.
We offer the best return policy in the industry. We give you 60 days to return any product purchased from GoVacuum. We will even include a return label with every order, and if for any reason the motor doesn't fit, send it back with the free return label, and we give you a full 100 Refund, no restocking fees.
Please feel free to call me or email me if you have any further questions.
Chris Jones
GoVacuum.com
1-866-468-2288
Posted on Nov 28, 2009
SOURCE: I took the filter assembly apart, now I can't get
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Posted on Jan 12, 2010
Broken Hose
Check out allvacumms.com. They carry a lot of oem parts.
Apr 11, 2014 | Nilfisk GM 80 Bagged Canister Vacuum
Nilfisk typ gsd servise manual
Hi there, Alec from VacuumSpot here.
There is not really a great service manual for this machine however if a parts diagram and list will help I can email it to you. Just use the contact us page on our website and request a parts diagram I will be happy to send it to you. RegardsAlec
Dec 08, 2012 | Nilfisk GM 80 Bagged Canister Vacuum
Nilfisk TYP GSD thermovalve
Hi There, The GSD components are now discontinued. You have to buy a new head unit to replace as a drop in unit.
If you are in Australia you can buy one here they are not cheap thought at $490
Dec 06, 2012 | Nilfisk GM 80 Bagged Canister Vacuum
Nilfisk vacume bearings
Hi There, If you could provide the model number of the machine that would help. However as a general rule if it is the motor bearings you are after then normally you replace the entire motor. If it is the roller brush you are needing bearings for you can get them from any bearing supplies store. If you are looking for any nilfisk parts in Australia then vacuumspot is the go.
May 27, 2012 | Vacuums
Looking for details for fitting dust bag in nilfisk king hoover
Hi There, I have made a quick video showing how to check the filters and also how to change the Nilfisk King Vacuum Bag. Take a look and you should be able to work it out.
Aug 30, 2011 | Nilfisk GDF2040 Vacuum
What is the correct wattage for the nilfisk gm 625 industrial vacuum and where can i get one from?
Take a look at this web page...
http://nz01.terabyte.co.nz/advanceclean/DocumentLibrary%5CGM82-625-626.pdf
Apr 26, 2010 | Nilfisk SS Mercury Bagged Canister Vacuum
Need directions on how to remove old cotton filter and install new one and same for HEPA filter on Nilfisk GM/GS 80.
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=Nilfisk+GM%2FGS+80+instruction+manual
Jim
Dec 03, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Vacuum emitting strong odors when it's on.
Hi there SmartAlec from NelsonVacuums.com.au here. I am a nilfisk vacuum agent and although i havent actually worked on one exactly the same as yours there are no Nilfisk with any kind of washable filters at all. I think you will have to replace it. If you are in Australia i can check out the cost of replacement filters for you just drop me an email with the exact model number.
Hope this helps.
Happy Vacuuming :)
Aug 31, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Sep 27, 2008 | Nilfisk Vacuums
Nilfisk GSD
are you talking abour exterior spring clips?
Jul 06, 2008 | Nilfisk GM 80 Bagged Canister Vacuum
Vacuums Logo
221 people viewed this question
Top Nilfisk Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
