Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Sandisk Cruiser not recognized
My Sandisk Cruiser has worked great for over 18 months. All of a sudden, it is no longer recongized by any computer.
I used the Windows Device Manager and tried to update the driver, but I have the latest version already installed. I tried uninstalling and reinstalling the driver, only to have the installation fail.
Then I tried plugging it into a new computer, and the Cruiser tried to the install its drivers as it normally would. However, an error always occurs during the installation, and the drive cannot be read.
As I have a ton of info on this drive, I would be ecstatic if anyone could help.
  • 5 more comments
  • rileysisu Aug 27, 2008
    It's a 4 GB Cruzer Micro.
  • rileysisu Aug 29, 2008
    Unfortunately, my Cruzer is not recognized by any computer, thus I am unable to add a shortcut to the disk.
    I tried the "add a shortcut" theory, but was unsuccessful.
    I've tried using the drive on 3 different computers, one of which I had never used before. My drive tried to install it's drivers (as it normally would), but an error occurs each time and the installation fails.
    Other USB drives work on my computer.
    I can't erase the files on my disk because no computer will display the drive.
    Besides, I desperately need to recover these files.
  • rileysisu Sep 11, 2008
    As suggested, I took my drive to 2 different technicians for data recovery. Both stated that the drive has a hardware problem, not a software problem.
    One also mentioned that the drive was running too hot and burned itself out. Is this possible?
    If so, is there any possible way to still recover my data?
  • 2,071 Answers
See if any bios updates are available, do check for your model mtrbd/system. Also, USB updates themselves from the vendor. XP should support USB drives alone, but glitches are known, in some cases to the flash drives themselves. I found one brand to be problematic, if that's yours try it in another system, that's Memorex brand. Here's a helpful link:
http://www.everythingusb.com/hardware/Storage/USB_Flash_Drives.htm
Posted on Aug 29, 2008
  • SanDisk Master
  • 19,396 Answers
Probably the auto loaded drivers are corrupted and are not working.
You can download the drivers from here:
SanDisk | Products | Driver Downloads
Download and istall drivers.
If this work don't forget to rate my solution
    Sergeant:
  • 241 Answers
You need to scan your drive in safe mode for virus
It sound like you have a VIRUS on the Flash Very common
Try to use you virus software. You have tried everything so I believe this is the problem
(plz feel free to rate )
  • Jayson Brollini
    Jayson Brollini Aug 29, 2008
    YOUR FLASH COULD BE INFECTED WITH A VIRUS!!!\
    Go to the manufactur website on howto remove the VIRUS in safe mode
    President:
  • 1,952 Answers
Format it and use...
  • mohammed marika thambi
    mohammed marika thambi Aug 29, 2008
    after insertin pen drive...goto address bar in ur system my computer ...then click drop down list box and select ur pen drive from tat..then the new window ll appear with full data
    else try in task bar
    Master:
  • 521 Answers
Just call a technician for the old recovery of data you have in that disk.he will be having the data recovery software cd to recover the old data successfully.and after that please do not use that same disk again.as it will harm all your system very much.every thing wiill be corrupted because of that.as i myself have faced this problem.
pls do rate the solution
thanks.
regards.
fixya expert team
    Master:
  • 763 Answers
If you dont mind to erase all the files on your sandisk and if no other solutions then format it to be use again.
CHARCOIS
    Brigadier General:
  • 5,158 Answers
Have you tried plugging in any other usb drives ?
Robert
  • 1 more comment
  • Roberta Smith
    Roberta Smith Aug 29, 2008
    I do a fair amount of data recovery work as well and that's certainly a good idea. Stop attempting to use the drive until data recovery can start as it would hinder what can be recovered.
    Robert
  • Roberta Smith
    Roberta Smith Sep 11, 2008
    it's hard to say why exactly the drive failed.... one other thing to do and i haven't read all the posts so you may have tried this.... plug in the device.... go to start... my computer... right click then select manage from the menu.... when the window pops up... you will see disk management... look at all the drives shown there.... cruizers have a tendency to show up as more then one drive... any drives there close to the size of the usb stick ?? if so ... note what the drive letter is... then go back to my computer... click on it ... is that drive letter shown there ?
    Robert
  • Roberta Smith
    I do have one alternative solution although i do data recovery i've never tried this on a usb stick... i can't tell you exactly that your data would not be damaged... if it works the drive should be recognized and hopefully you would get your data back...
    Robert
    Genius:
  • 3,422 Answers
Did you try using this flash drive on another PC?Let me know if it works there or not?
Posted on Aug 28, 2008
  • SanDisk Master
  • 6,487 Answers
The sandisk is still recognize by computer when plug in right? if that's the case try to , Right click on any part of your desktop screen then click on New shortcut , then on the box type in F: then click ok, after that check if you can now access your sandisk using the shortcut that we have created.
Hope that helps.......
  • Mark Gil
    Mark Gil Aug 29, 2008
    Try downloading the latest software for your sandisk hopefully that will fix this problem....
When I plug my sandisk into the computer, I can't find it-but if I plug memory stick into same plug I can find it. How come my computer is not recongizing the sandisk
i was having the same issue, the usb port i was using was in the front of my pc, it wasn't recognizing it.. i plugged it into one of the usb ports in the back of the pc and now it seems to be working fine... hope this helps
Jul 25, 2009 | SanDisk Sansa e260 MP3 Player
SD800 no longer recognized!!!!!!!!!!!!!!!
Best solution for SDHC is a high speed card reader.
One that hooks up via Firewire.
Some of the compatible cameras with the higher capacity, faster cards are not recognized when connected to the computer... great work around and downloads are quicker too.
Jun 05, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Cruzier 4.0 pendrive is not recognized by my computer
the home computer has a small chip onits mother board called disk controller. its this controller which recognises it.so the software driver is corrupt and needs reinstallation or the hard ware controller is faulty.
Jun 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Does not recognize
The dinging sound is the USB port telling Windows that a device is connected, and does not necessarily mean that Windows recognizes a device.
Are you using Windows Media Player 10 or higher?
May 21, 2008 | SanDisk Sansa e250 MP3 Player
Songs got deleted from Sandisk on its own and computer does not recognize the device.
you can buy a recovery software from scandisk here
http://www.lc-tech.com/software/rescueprodetail.html
to get it to work with the pc you need to go here !
http://www.clubic.com/telecharger-pilote-132683-0-sandisk-sansa-e250.html
its in french but just get the firmware file download it and install it !
if this dont work you need to update your windows software this is the mainreason its not working it should usually detec on its own but you windows is probbably missing a few updates!
Jan 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa Connect Problem
I had the same problem with my Sansa Connect. It refused to start up when connecting to my computer. I think it may have something to do with not refreshing my music every so often. I tried the Recovery Tool, but it did absolutely nothing. Same problem was still there. So, I did a factory reset and it worked. No problems. I would recommend refreshing music regularly to avoid this problem.
Dec 26, 2007 | SanDisk Sansa Connect MP3 Player
Computer doesn't recongize my mp3
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Jun 23, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
169 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
