Question about Pioneer Audio Players & Recorders
My pioneer radio tuner F77L has recently begun to lose the signal especially on FM when tuned to radio 4. It is connected to an exteranl aerial and this seems to work for other stations. I've tried using different preset positions but it happens whichever preset I tune the station to.
SOURCE: onkyo tx 902
I have a TX-902 owners manual.
It states:
Classified Memory Function. The memory can be divided for different users or programs of stations.
How to classify stations. With this model, six classes (Class A to F) are available and stations can be memorized in any class. A total of 30 stations can be memorized in any class. A total of 30 stations can be memorized.
1. Tune in the desired station.
2. Press the MEMORY button. The MEMORY indicator will flash for 8 seconds.
3. Press the desired Classified Memory button (one of buttons A to F). The station is memorized in the selected class with the memory number which is the smallest of the unoccupied numbers in the class.
By repeating the operations above, up to 30 stations can be memorized. Any more will produce "FULL" notice.
How to cancel memorized stations:
Retrieve the class number you want to cancel and then press the MUTE/MODE button while holding down the MEMORY button. Another station can be memorized with the memory number which has been cancelled.
Hope this helps.
Posted on Jan 08, 2008
  • 105 Answers
SOURCE: Help with fm presets
I'm not sure on this particular model, but often if there are seperate buttons for the station presets you just tune to the required station and hold the preset button you want in until you hear a beep - then the station is memorized in that preset.
However in this case the preset up/down and enter/memory buttons are used - the manual is available here:
http://www.sherwoodusa.com/cc_manuals.html
and full instructions for setting presets both automatically and manually are on pages 35/36.
Posted on Mar 16, 2008
  • 3422 Answers
SOURCE: Can't tune to any radio station
HI,
I'll let you know if there is a factory reset button button for this model.
Posted on Jun 12, 2008
welcomejee
  • 10594 Answers
SOURCE: I have a Sherwood RX-2030R,
Check Sherwood RX-2030R specification of AM tuning frequencies limits in user manual.
Please confirm was it tune before below 1320 and above 1710 AM meter band?
Posted on Nov 06, 2008
robotek
  • 1512 Answers
SOURCE: setting channels for am and fm on pioneer rx 570
Hi gbrokaw
Generally speaking, you select the station you wish to store, then depress and hold down the preset button you wish to store it to. After a few seconds, the screen will blink, and the will be station stored. On to the next one. Try this and see how you get on. If you have any problems, I am happy to help you help you sort it out. Cheers
regards
robotek
Posted on Nov 07, 2008
I bought a Bush digtal/ AM/ FM radio ("retro transistor" style). DAB reception dropouts lasting several seconds each time have started occurring recently. AM/ FM is ok.
Constant usage of DAB should not cause it any damage ever. The dropouts are very characteristic of a poor signal reaching the DAB tuner, as digital is either there, or not there, nothing in between.
Check the aerial connection if any, the rod antenna if any, and try moving the antenna (whatever it is) to a better location, usually higher up, away from thick walls, and away from speakers if any.
Apr 18, 2015 | Grundig FR200 AM/FM/SW/DAB Radio
Electrohome ean 0s700 radio wont play
Check the aerial connection. Some FM radio's will mute the static and only pick up strong signals. If it is an FM AM radio check the AM radio. If that is OK and the connection's are good you might have faulty Tuner circuit, which would need a trained technician to look at.
Dec 10, 2014 | Audio Players & Recorders
FM Tuner not receiving - Yamaha R7 receiver
Take the cover off and look at the cable that connects the tuner to the main board. Make sure it is connected straight and tight. Make sure all screws in the back are tight, just in case it is a grounding issue. Iff all checks out and you still have issues, replace your tuner.
Apr 30, 2012 | Yamaha Audio Players & Recorders
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
I'm trying to connect my cablevision coax to my Pioneer VSX-1019 reveiver so I can listen to FM radio through the tuner. The antenna connection on the receiver is a female European PAL (also called as...
Is this what you need? http://cgi.ebay.com/4pc-Gold-Plated-Aerial-Female-Aerial-Female-Adapter-/180435080974?pt=LH_DefaultDomain_0&hash=item2a02c4d70e
although I would be surprised if the signal you have would be correct to supply your fm tuner, you may be better off with something like this (depends on how good your fm signal is locally) http://cgi.ebay.com/FM-AERIAL-KIT-RADIO-RECEIVERS-BALUN-UNIVERSAL-/310283558296?pt=LH_DefaultDomain_3&hash=item483e575d98#ht_2068wt_876
Alternatively, and I know this sounds crude, poke a long piece of wire into the centre of the aerial socket on your tuner and pin it to the wall or a door frame, it often works if you have a decent signal to begin with.
Jan 11, 2011 | Pioneer VSX-1019AHK A/V receiver
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
Akai Stereo Tuner Amplifier(AA-1125).with faulty tuner
It could be that IC's that control the AM/FM radio have failed and need replacing. On the circuit diagram it has two numbered LA1240 and LA1230. Though it's unlikely both would fail at the same time. Unless you were not using the AM radio and that failed first and then the FM one went. However there is a 7 pin device which is called the Front End. This is located connected to the tuning gang. The metal thing with flanges that in-twine. Both the AM and FM aerial leads go into this before reaching the IC's. It contains a FET and some transistors. It has 12 volts on pin 4. And there is a 300ohm output on pin 3, where both FM and AM signals come out. So you can check that out. If it's not showing 12 volts on that pin there is something wrong or the 300 ohms on 3.
You could at one time get a replacement Front End, but after all this time it's unlikely they are still made. But with a lot of work it should be possible to get inside the Front End and replace the faulty parts.
The service manual is free and online. Just type the model number and service manual into google and you will see the free PDF of it. Parts numbers for the Front End are mentioned, just in case somebody still stocks it!
Jul 02, 2017 | Audio Players & Recorders
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Will not tune any radio station, fm or am. everything else works fine. May be damage resulting from lightning, through the antena input.
It is very possible the fm tuner pack is damaged from lighting,if you have voltage going to the fm tuner pack im sure your tuner is bad pioneer part number for your tuner is AXQ7231
Sep 26, 2009 | Pioneer VSX-D811S Receiver
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
