Question about RCA CC-432 Camcorder
My LCD moniter is getting warm
The rear of the LCD monitor on my camcorder is hot.
    Master:
  • 473 Answers
The light that illuminates the LCD monitor can get hot. To cool it down, close the LCD monitor and turn off the camcorder.
Posted on Sep 06, 2005
Hello sir i have a broblm in my samsung synicmastr 19" blak, when i switch on the moniter, the moniter is with in 2 or 3 second automitically off the display light but moniter is still on and display...
this problem can occur cause of two cases 1 problem with LCD panel (replacement can solve) 2 power failure in side moniter (repairing moniter can solve)
thanx PLZ vote
Feb 22, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
My vx2035wm starts flickering real bad after about 2 to 4 hrs of work. it only stops if i turn the screen off for 2 to 4 hrs, then it repeats. please tell me what the problem with my moniter is
Does it happen *ONLY* when connected to *YOUR* computer (implying that the video-card in your computer is failing when warm) or does it happen when connected to *ANY* computer (implying some heat-related problem inside your LCD monitor) ?
If the monitor is still under warranty, exercise the warranty to get it fixed. If the warranty has expired, it's cheaper to buy a new monitor than it would be to repair it.
Mar 03, 2010 | ViewSonic VX2035WM LCD Monitor
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
15.6 lcd wide moniter (low light)
It's LCD pannel problem
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
Oct 03, 2008 | Acer AL2216WBD LCD Monitor
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
Samsung SyncMaster 510N
its time for u poeple to buy a new moniter .....or get it repaired by a prof tecnician.....the electrons which bambard on the picture tube at a point of time they become weak...n they loose there capacity......so the moniter starts dim and after wards when the moniter heats up it get fine !!!!!!!!!!!!!!!
Oct 11, 2007 | Samsung 510N 15" Flat Panel LCD Monitor
Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Oct 06, 2007 | Gateway FPD2275W LCD Monitor
RCA CC-432 Camcorder Logo
43 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
