Question about Samsung Refrigerators
My fridge has stopped working on my samsung RS21FCNS can you help.
    Genius:
  • 1,142 Answers
  • First off check the power. You should check to see if the receptacle is working properly, use a circuit tester for this. If the receptacle doesn't’t work, check for a tripped circuit breaker or blown fuse.
  • Other problems that could be associated with a fridge not working include, an electrical cord that is damaged.
Posted on Aug 27, 2008
4 Suggested Answers
SOURCE: fridge
this link will help.
http://www.howtomendit.com/answers.php?id=47453
Posted on Sep 18, 2008
  • 121 Answers
SOURCE: RS21FCNS - No water
It could be the water soleniod screen is clogged or if you have a filter clogged. Take the water line loose and check the screen first.
Posted on Sep 25, 2008
imufo2
  • 3773 Answers
SOURCE: I removed the ice from
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 27, 2011
HOW TO CHANGE FRIDGE LIGHT BULB SAMSUNG rl41ecps
I have Samsung American fridge RS21FCNS and need to change light in the fridge
May 23, 2012 | Refrigerators
Rs21fcns ice shute door not closing
That's normally the solinoid that is defective when the chute won't close which is above that door and is a pain in the a_ _ to repair so I would call a tech to handle that problem.
Sep 26, 2011 | Samsung Refrigerators
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
Freezer and fridge don't cool at all. everything else works fine
Heya,
There is a fault with samsung fridges that when it goes on defrost it will not start the compressor or the fans again. If you turn on the power the fridge should run for a couple of hours and then stop if so you will need to get a tech out to order a samsung yellow sensor and a fridge defrost isolation sensor. If the fridge does not work at all if you would like i will talk you a couple of little checks before calling someone out.
Hope this helps
Jan 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge not working
Hi steven, Maybe this could help? Has anyone moved the settings on the fridge? Your fridge is actuallty controled by the freezer with a fan and flap in the fridge compartment. These sometimes ice up and do not let the cold air into the fridge if this is the case then i would switch it of and defrost it ( Yes it is supposed to frost free ) But they do fail. Check to see if it has two compressors on it? see if the fridge one is work and hot as it could be independant from the freezer depending on the spec!
Hope this helps?
Dec 28, 2008 | Refrigerators
RS21FCNS - No water
Sep 25, 2008 | Refrigerators
Fridge
Aug 27, 2008 | Refrigerators
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Samsung side by side
you can reset the fridge by pushing "Power Freeze" and "Power cool" at the same time
it worked with my fridge Samsung RS21DAMS which stopped after a power cut and was also flashing at the digit of the fridge temp display
Mar 28, 2008 | Refrigerators
Refrigerators Logo
318 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
