Question about HP LaserJet 2550L Printer
New Memory Installed
I have HP laser color printer 2550, I purchased 128MB RAM I already installed the memory but is not working, what is the additional procedure that I have to do rather than what explained in the reference manual
Regards
Eyad
  • eq-trading,,
    have u tried to install the driver aledy??
Hi ziau,
We purchased new printer ram with toshiba chip set, we try to install the ram but it wouldn't work, we follow the same procedure in the manual.
We did not install any driver and which driver you mean
Regards
Eyad Qudeimat
Posted on Aug 27, 2008
Initializing scanner hp cm6040
Most common cause of the error on this printer is the memory on the CPB (copy processing board) is bad. This board is picky about memory and typically only works with the actual HP memory designed for it. The easiest fix is to use the memory that is currently installed on the formatter, which is identical, and purchase 3rd party memory for the formatter, which will support any compatible memory.
May 07, 2016 | HP Color LaserJet CM6040f MFP Q3939A...
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
Memory expansion
The Lexmark E260dn has 32MB of memory pre-installed and you can add a maximum of 128MB to this. The type of memory is 128MB DDR1-DRAM. The part number is 1022298.
Dec 07, 2009 | Lexmark E260dn Laser Printer
How to start HP color Laserjet 2550 printer HP Laser Jet 2550 Printer
first your printer connected to your PC and install the printer software for printing. After Installation you press the power button of your Printer, so your printer is on go for Printing Documents/Pictures.
Thanks
Aug 16, 2009 | Office Equipment & Supplies
My beloved Brother hl 5250dn has refused to print
The printer needs more RAM memory. Check into purchasing and installing more RAM. Printers use RAM to print graphics.
Aug 14, 2009 | Brother HL-5250dnt Laser Printer
Manual for RAM upgrade
Memory Upgrade for Dell Color Laser Printer 3100cn Printers, the Dell Color Laser Printer 3100cn Printers takes the PC133 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Dell Color Laser Printer 3100cn Printers to up to a maximum of 576 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed.
http://www.memorystock.com/memory/DellColorLaserPrinter3100cn.html
You should be able to get crucial or the likes to send you the correct memory - as for where it goes that will be in the manual
May 25, 2009 | Dell 3100cn Laser Printer
I need to add extra memory now my lap top works with 128 MB i need to be 256 MB
thats no problem sir,u can upgrade the memory cards of the computer to the level which it supports may be 1gb,2gb or 4gb.....
u can purchase another memory stick of same specifications because its availiable is different size like 128Mb,256Mb,512Mb or 1Gb.....you can use any one according to your wish...
Apr 26, 2009 | Toshiba Tecra 8200 PIII-850MHz/ 256MB/...
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
How to install new ram into the 2840
Unplug the machine. On the right side of the machine you will find a cover. Remove the cover and you will find 1 open slot. The machine can take a total of 224MB (96 is built into the machine) leaving 128 available. The memory type is 100pin, 133MHz, SDRAM DIMM.
Simply click the memory into the blank slot and replace the cover.
Once completed, plug the machine back in and print a configuration page. The memory total should be at 224 once you have installed your 128MB.
Good Luck
Jul 24, 2008 | HP LaserJet 2840 All-In-One Printer
Both ram not detect
More than likely the 2nd slot your trying to use is bad, however before you make that assumption try inserting a stick in the possible bad slot by itself and see if it will post. Let us know :-)
Sep 17, 2007 | HP (D7580-60003) Motherboard
HP LaserJet 2550L Printer Logo
Ben Johnson
