The Computer has trouble restarting Windows XP. I have to shut it down and unplug it for at least 2 minutes in order for it to start normally past the black screen. Otherwise, it will keep restarting over and over unless I select safe mode. I have Automatic Updated switched from "automatic" to "notify me when there are updates but don't automatically download and install them" because some updates may require restart of the computer.
    Brigadier General:
  • 5,158 Answers
I'm guessing from what you are saying, that it will in fact boot to safe mode. the culprit is most likely a resently added program. my other favourite is thermal shut down. remove the cover (after it is shut down and power is removed) and see if it's filled with dust and dirt. when the case is off start the computer up. are all the fans working as well ?
Robert
Posted on Aug 27, 2008
My computer won't start, it appears to have no power. For the past 2 weeks when ever I would start up it up I would have to constantly push the start button 3 to 5 times till it would power up. Now it...
Most likley you have a fried power supply. Try this first unplug the computer from the power cord for 5 minutes then plug back in and go into safe mode see how to go into safe mode below.
To start the computer in safe mode 1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Chris Thrash
B52computers
Please Vote
Jan 10, 2011 | Gateway GT5014 PC Desktop
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
When my laptop is turned on, it shows, We apologize for the inconvenience, but windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped...
You have corrupt or deleted windows files or possibly a hardware error. The first thing is to try a repair using a Windows XP CD that came with your system.
XP REPAIR INSTALL 1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS. Check your system documentation for steps to access the BIOS and change the boot order. 2. When you see the "Welcome To Setup" screen, you will see the options below. This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER.
  • To repair a Windows XP installation using Recovery Console, press R.
  • To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup: do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you do not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R". 4. Accept the License Agreement and Windows will search for existing Windows installations. 5. Select the XP installation you want to repair from the list and press R to start the repair. 6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. 7. You will need to apply Windows updates after this procedure.
Sep 21, 2010 | Dell Inspiron 1545 Notebook
My computer fails to boot. I shut it the normal way and now doesn't get past basic start up.
press f8 button many times when you start the computer, it will take you to the options where you select boot by safe mode. In this way you will be inside your windows. Once inside, shut down the computer in the normal way. once shut down now restart the computer in the normal way. If it does not start, you need to change your windows.
Sep 18, 2010 | Computers & Internet
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Computer freezes after bios screen on every restart.
One thing you could check is what order your computer is booting from. CD drive hard drive then other. Should be hard drive first. Go into the bios to do that. If you hold the power button down for 5 to 10 seconds the machine should physically shut down rather than unplugg. The unplug thing sounds like its in the power settings. But I've never heard of power settings being connected to bootup except for a password. Anyway a wild guess is check the bios bootup order.
Dec 31, 2009 | Toshiba Satellite® A215-S4807 PC Notebook
Pc keeps loading and restarting again, it wont go past windows xp
I keep coming back to this, thinking about it, leaving and coming back to this. I have seen this before and the only thing that I could do to fix the issue was to do a Windows Repair using the original CD. The problem with this is it looks a little deciving and could be complicated. Put the CD in, accept the ULA and when it gives you the option to repair, hit R. Go through the prompts a little further. It will look like it is reinstalling Windows completely, but it is actually reloading just the system files that usually become curupt. When the system comes back up, it might look a little different, but all of your programs and files will still be there.
Mar 15, 2009 | Dell Dimension 4400 PC Desktop
I am unable to connect to aol. Screen says invalid password. This has been going on for weeks. I have changed passwords numerous times. In the past the new one works for a few days, then the whole...
Hello!!!
Check Your Keyboard Connection, Then Restart Your Computer
Checking the connections and restarting the computer will make sure the keyboard is plugged in properly and the computer is correctly recognizing the keyboard.
To check the keyboard connection and restart the computer:
1. Shut down your computer:
* If using Windows® 98 or Windows® Me, click the Start button, then click Shut Down. In the What do you want the computer to do? section, choose the Shut Down option by clicking it, then click the OK button.
* If using Windows® XP or Windows® 2000, click the Start button, then click Shut Down. Click the What do you want the computer to do? drop-down menu to open it, choose the Shut Down option from the list, click it, then click the OK button.
2. Follow the cord from the keyboard to where it plugs into the computer.
3. Unplug the keyboard cord.
4. Wait for about 30 seconds.
5. Plug in the keyboard cord.
6. Turn on your computer.
Nov 05, 2008 | Computers & Internet
Having Trouble Starting
Enter Safe Mode with Networking.
Update Video drivers.
Restart the system in normal mode and if still no go then you have to reinstall Vista from CD's.
Sep 25, 2008 | Toshiba Satellite A305-S6834 Notebook
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
