Question about Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser CX11NF
We can't do stand alone copies. When we push "start" (either B&W or Color), screen says "copying" and data light flashes, but nothing happens. Can't cancel either. Problem occurs whether we put doc in feeder or place on flatbed glass. Help!
  • 1 more comment
  • bbbc Aug 29, 2008
    Reset all possible menus, however when I hold down the reset button for a period as advised in the manual, it does not go into reset mode.
  • bbbc Aug 29, 2008
    Did all possible menu resets, however when I held reset button down for a period as advised in the manual, it would not go into reset mode.
    Copy problem still exists.
  • bbbc Aug 29, 2008
    So far, so good - thank you!
    But the problem was intermittent, so a few more copy attempts to know it's fixed!
    Master:
  • 521 Answers
Its not the problem of reset.i m having the same problem with my canon mpc 400 printer.i my self tried to repair it by the reset method.nothing happens.the company service service person told it was a scanner problem.i replaced the scanner unit which is copying my documents.and then it started working properly for two months.but after that same problem appared .the company does not give any garantee for this scanner units.just replace your epson printer and get the hp printer.in hp the problems like that are very cheaply solved.hence changing the scanner unit in your printer will definately help.it will be costly near about
50$.but i will not advise that.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 29, 2008
    President:
  • 1,952 Answers
Hi, don't know if you've sorted this but there is an interlock on the left hand side of the machine where you put the cartridges in. If you put a screwdriver in and push up, you can rotate the carousel manually, then you'll be able to remove the cartridge.remove tat and check it oput..the pro may cause due to fault in the flow of cartridges and also contact between cartridfe and roller
  • Epson Master
  • 1,879 Answers
Is the Aculaser connected to a computer while doing a standalone copy ?
Disconnect the Aculaser from anything it is connected (except the power source) then powercycle it (OFF & ON)
Posted on Aug 27, 2008
  • 157 Answers
Check the toner
Sounds like a toner problem .. might need replacing
    Master:
  • 848 Answers
Just unplug the printer for 15 minutes ...this will reset your unit ......you will get this error....
    Genius:
  • 2,785 Answers
Plz try to reset the machine by consulting your manual.
Epson ACULASER CX11NF paper Jam error every time I print
you may wanna check if the paper that your using is a laser paper, check the mp tray, reload the paper and check the settings on your computer using thicker needs to match the setting on your driver you may also wanna check if your printer can do a stand alone copy so that we can identify if this a hardware issue or a driver issue.
hope this will help u
May 10, 2010 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser CX11NF Printer is offline
you need to go to settings ,then printers then right click from your mouse on your printer ,then put it online..thats it...i hope it will work..
Mar 25, 2010 | Epson ACULASER CX11NF All-In-One Printer
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF we have to replace the PCU every 3 months,
The photoconductor (PCU) is used whenever you print anything. They should last between 10,000 copies (colour) and 20,000 copies (black only), so roughly 15,000 pages. If yours is going through them quicker it could indicate that there is a problem, try giving Epson Customer support a call and ask for advice.
Mar 25, 2009 | Epson ACULASER CX11NF All-In-One Printer
ACULASER CX11NF Photoconductor reset - chip?
The reset chip will not provide you with a long term solution to your problem. The photoconductor unit is now full of waste toner and the photoconductive drum, prime charge roller and wiper blade are all worn, this is the cause of the message. Your only real and the correct solution is to replace the Photoconductor unit with a new one. Remember that this is part of the consumable set for this printer and is therefor costed in as part of the cost per page.
Should you proceed with the replacement chip, you will be opening yourself to deminishing quality print and eventual failure of the unit.
Gremlin11
Jul 24, 2008 | Epson ACULASER CX11NF All-In-One Printer
ADF jam
Turn off printer and unplug it from power supply.
Check ADF if it appears to be damaged ( open the top portion so that you can check the mechanisms ) unplug the ADF cable from back of scanner and replug it, replug power cable, turn it on and try scanning using adf again.
Feb 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson AccuLaser CX11NF
I had this problem. Try unplugging any usb connection to the computer, turn off, then turn on and then try a stand alone copy. It was my USB connection to the computer which had locked up the copier.
After this it was fine.
Jan 23, 2008 | Epson ACULASER CX11NF All-In-One Printer
HP d135
Try posting your question in the correct section. This category is for Epson CX11 machines
Dec 04, 2007 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
111 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
