Question about RCA CC-432 Camcorder
Weird error message
I'm getting an error message on my camcorder that appears as a combination of letters and numbers (i.e. E03).
    Master:
  • 473 Answers
For Models: CC6254, CC6364, CC6374, CC6384, CC6394, CC9360, CC9370, CC9373 There may be a simple solution. Do the following: * Turn your camcorder's power off, then disconnect the power source (battery or AC adapter). * Remove the clock battery, if equipped with one. * Wait a few minutes, then reinstall the clock battery. Reconnect or install the power source — battery or AC. * Then try turning on the power again.
Posted on Sep 06, 2005
When in play mode the following error appears E03 Remove and reattach battery unit in safe mode
As you have already removed the battery and re-attached it, try to clean the contacts between the battery and the camera.
I had tried this and it did not work so I tried Tapping on side of Camcorder ( gently on palm ) and I worked, after 2 or three times while message appeared.
Below are few reasons what causes E03 Error
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with each other, the tape is not wound because of overload to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette having no tape inside.
6. The tape slackens and no pulse is produced until the slack is taken up and the tape comes into the normal
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | JVC GR-DVL100 Mini DV Digital Camcorder
Error code E03,camcorder shuts down,won't eject tape.How do I fix it.
E03 means the motor drive has failed.The damage is permanent. The camcorder GR-AX5 is too old to repair.Recycle it and buy a new one.
Nov 10, 2009 | JVC GR-AX230 Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
to the mechanism.
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
Error E03 -
I tried Tapping on side of Camcorder and I worked, after 2 or three times while message appeared.
Oct 19, 2007 | JVC GR-DVL100 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Mar 19, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
RCA CC-432 Camcorder Logo
153 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
