Question about Crosley CDE6000 Electric Dryer
CDE6500W Not Heating
I'm not sure if my heating element is bad or one of the fuses is bad. Can I tell if the heating element is bad without buying anything or having a service guy come out? does not heat
  • Anonymous Nov 04, 2008
    MY DRYER IS TURNING BUT ITS NOT HEATING UP
  • 550 Answers
Most common cause is burn out of the thermal cut-out. These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
Clean the exhaust ducts all the way to the outside wall, lots of vent hoods block over time. then examin the exhaust duct for devices that look like this CDE6500W Not Heating - ce71633.jpg or like this b8e6372.jpg with wires connected to the terminals. there may be 2(hi lo), test with a flashlilight bulb or ohmmeter conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
Dishes are not clean after cycle, not sure what to do , opened in middle of cycle and steam comes out so water appears to getting hot, not sure if rotors sprayers are turning how can I tell, washer is...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 11, 2011 | Frigidaire Dishwashers
White and pasty, thinly covering all dishes, utensils. Appeared out of nowhere after using this dishwasher for 6 months without a problem.
Dishwasher
How to Buy
heatman101
Dec 21, 2010 | Dishwashers
Have white residue left on dishes after cleaning cycle. Have tried cup of viniger, washing without dishwasher soap, very hot cycle- all left residue.
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker
Nov 11, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
I have a Maytag Model MDB7130AWW and it appears the water is not heating up. I am getting white stuff on the dishes. How do I tell if this is a bad heating element, how do I order one, how much does it...
Check your heating element..
A bad heating element causes many problems in dishwashers…
That is not that hard to fix and you can easily buy the parts yourself online...
heatman101
Sep 06, 2010 | Maytag MDB5100A Dishwasher
Where is the thermal fuse for a crosley cde6500w
The thermal fuse for this dryer is located on the right side of the heating element behind and near the top/left of the drum. You will see two white wires leading to it. The Thermostat is right above the heating element - two red wires lead to it.
Apr 14, 2010 | Crosley Dryers
Dishes are not cleaning as well as they use too. I've checked for plugged water spray holes. How can I tell if the sprayers are turning? Anything else I should clean out?
heatman101
dffg12
Mar 23, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Dec 12, 2009 | Whirlpool Dryers
Not heating up, fuse or heating element? How to tell?
Hi, Get me the model # and I can help you further.
Thanks
Vic
May 23, 2009 | Dryers
The dryer works but does not heat
Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
The part number is 53-1641. It comes with a high limit and is around $50. You must pop the top on this unit and you will finnd the element in the rear of the dryer. A simple and easy fix.15081c8.jpg
May 19, 2008 | Crosley CDE6000 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
143 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
