Question about RCA CC-432 Camcorder
Can't rewind my tape.
When I try to rewind, nothing happens.
    Master:
  • 473 Answers
The tape may already be at the beginning or the end, depending upon which function you are attempting.
Posted on Sep 06, 2005
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
I have not used my handycam for a few months, and now it does not record. Push rec button and nothing happens .The camera will take pics rewind,fast foreward and play but push record and nothing.
The camera wont go in record mode if the tape protection tab is over hole on rear of cass tape, maybe you ought to buy new tape and try again, very little goes wrong on those cameras my friend, there is nothing on market as good these days I can tell you.
Jun 15, 2010 | Sony Handycam DCR-TRV460 Digital Camcorder
Tape compartment will not open, has tape inside
hi you can try to press eject but nothing gone happen because the tape is stock inside , thats means you
will have to open the camera to remove the tape
manally/ but you can try your pwr pack adaptor in the cam then press rewind if you got the pwr on.,if that rewind let it go tothe end the press eject
if its not pwr on doesnt look good you will have bring to service dep at a dealer you is good in cam service
Mar 03, 2010 | JVC GR-FXM39 VHS-C Analog Camcorder
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
Cassettes not rewinding
The heads could also just need a good cleaning, either professionally or using a head cleaner dv tape. It's important to remember to always use the same manufacturer dv tape all the time. Evidently, Sony and Panasonic do not mix well, and the lubricants from those two tapes combined will gum up the works. If you use Sony dv's, always use a Sony head cleaner and vice versa. Cold can also cause those lubricants to gum up. Sometimes simply fast forwarding will loosen things up.
Nov 25, 2007 | Video Cameras
Entire camera is locked up
THIS IS A PROBLEM WITH SAMSUNG SCD 353 LET ME NO IF U NEED MORE REPAIRS
Oct 21, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Loud noise on rewind
You may have an idler gear wheel which has been damaged- perhaps broken/worn gear teeth or something afoul in it's drive mechanisms. Check this idler which sits down in between the supply and take-up spindles. You should be able to see this with no tape loaded. This idler should also move freely from supply to takeup- if it is sticky in movement this could be the problem. If your idler is broken, you may be able to replace it. Check with a service center- or a parts supplier. MCM electronics is one such supplier- there are others.
Oct 01, 2007 | JVC HR-S3901 S-VHS VCR
No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Jul 30, 2007 | Canon ZR100 Mini DV Digital Camcorder
Will not play back
Usually if there is no impact injury involved or nagging intermittent past problems, you probably have a head cleaning issue. Try a dry type (reccomended) cleaning tape. Should be able to purchase at Best Buy or similar store. Good luck, magic seadog
Jun 10, 2007 | JVC Cybercam GR-DVL805 Mini DV Digital...
All of a sudden some of my tapes will not playback and others will??
I have been experiencing the same problem with my Panasonic PV-GS120. I don't know the root cause or real solution, but I found if I keep playing the tape, rewind->play->rewind->play, eventually I would get the image back normal. I think I would try to clean up header with a header cleaner to see if it helps or not. If not, I plan to submit a request to Panasonic support to check out possible solution. Good luck.
Oct 22, 2006 | Panasonic Palmcorder PV-GS120 Mini DV...
RCA CC-432 Camcorder Logo
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
