Question about OKI B6300n Printer
Oki B6300 with fault code 003-350.
Turned machine on & off several times.
Removed all cables.
Any advice?
Thanks
DW
  • weedo719 Aug 27, 2008
    The only thing it says is switch off & on again.
    Thanks
    Dw
  • Roberta Smith
    Roberta Smith May 11, 2010
    closest error code for that is printing parameters. In the screen where it gave you the error code was there anything else ?
    Robert
SOURCE: OKI B6300 error message: Please
Your fuser has gone out and will need to be replaced to work. Rather simple to replace on your own.
Posted on Aug 20, 2008
Touch2Heaven
  • 145 Answers
SOURCE: Hello , my oki b6300
replase fuser
or
clear fuser counter
Posted on Jan 21, 2009
SOURCE: OKI B6300 Drum problem
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
Posted on Feb 12, 2009
rylee_smith
  • 8619 Answers
SOURCE: I GET ERROR CODE 010-349 WHEN TURN PRINTER ON
Hi!
The error issue your printer is facing means "Fuser STS Front Disconnection fail"
First try to reset the printer by powering off and then on. If the problem still persists then you need to detect fuser or fuser assembly which is required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 25, 2009
KudesNIK
  • 22 Answers
SOURCE: How to solve "reboot printer
This is a fuser disconnection error. Try to remove the fuser and put it back securing properly in its place.
Posted on Sep 24, 2009
Oki b6300 not printing on the right side
1. change cartrige if problem not solved 2. there is mechanic problem 3. or LSU optics are not clear
Aug 27, 2014 | OKI B Office Equipment & Supplies
Aquired oki b6300. it has old company info and passwords. how to reset for my company?
1. Turn off the printer.
2. Hold down the shift and LF buttons at the same time and turn the printer back on
3. Release the buttons
4. The printer should be reset to factory defaults now
Sep 15, 2013 | OKI B6300 Laser Printer
OKI B6300 Laser Printer stays in a "please wait"
An initialisation fault has occured
There is a component fault with the machine.
The infomation supplied is insufficient to diagnose the fault any further
Feb 14, 2011 | OKI B6300 Laser Printer
OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
Hi!
Thanks
Rylee
Jun 25, 2009 | OKI B6300 Laser Printer
Can't put back ink cartridge in machine. wont' go back in
USE A BIT OF FORCE, NOT TOO MUCH, BUT YOU WILL FIND IT CLICKS IN
Jun 16, 2009 | OKI B6300 Laser Printer
I hope this helps!
Feb 12, 2009 | OKI B6300 Laser Printer
OKI B6300n Printer Logo
695 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
