Question about ASUS Computers & Internet
Asus a7m266 was watching somthing on a tv tuner and computer died, every time i switch on all i get is a repeditive 1 second long beep, then 1 second pause no bios or display
  • Tuomaxius Aug 27, 2008
    tried a bios reset, did nothing, that would normally only help if it had been too overclocked tho, nd i avent touched that
  • 123 Answers
Tuomaxius,
its ur video card..
if u have a built in video card, then install a new 1..
but if ur video card is not built in,then try to unstall that,clean the pins by using a white eraser, ONLY WHITE ERASER.. then try to run ur computer..but if that one doesn't work,replce ur video card already..
Posted on Aug 27, 2008
    Problem Solver:
  • 3 Answers
Try taking out the battery on *********** board, then put it back in and try it. this should reset your bios.
also there should be a 2 prong jump block on *********** board to reset bios.
check *********** boards book for location of this pin.you will need a jumper to do this. if you have any old hd's or cd dvd drives laying around you can use one of them. the little black thing for master/slave jumping..or an old mother board.
i have like 4 of them in the bottom of my case just incase i have to reset bios the hard way.
hope this helps.
willowcreekjim
Why cant I change channels when recrding 2 progs?
Hello Anonymous,
You did not specify if you are using a DVR capable cable/satellite box, which I what I presume is the case.That DVR has two tuners in it - each tuner allowing you to watch and/or record two programs at one time and in any combination.If both of those tuners are used for recording then you cannot watch another "live" stream as there no available tuners to tune and display (or stream to the DVR hard drive for recording). You can only switch between the two recording programs.
As a side note, if your TV has a built-in tuner, you can split the cable and have one going to the DVR and the second run going to the TV set. You can then use the TV's built in tuner and watch what anything it can get. It won't get scrambled digital cable but will get analog and Clear QAM channels.
Feb 15, 2015 | Televison & Video
Asus u52f troubleshooting
buy tv tuner card and you will be able to watch tv on your computer
Nov 27, 2012 | ASUS U52F-BBL9 Laptop
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
I have an Asus laptop M51V and cannot figure out how to watch TV through it and what the mobile TV antenna looks like- can you help?
What you could do is buy a usb tv tuner, or the ones in the express card slots, some have it but its called the PCMCIA slot.
Mar 10, 2011 | ASUS Computers & Internet
The picture goes blank after about 3 or 4 minutes. I have to shut it off and wait a few seconds and turn it back on. It does this 3 or 4 times and then it seems to stay on.
When the picture go black,tv still have audio?Yes,than those 1 or 2 long boards that call the LCD inverter boards are the problems are dying.If picture goes black and no audio at all?Yes,than the tv Tuner signal board have problems is dying.The tv Tuner signal board it is the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shojimmy.com,Ebay.com to buy those 1 or 2 refurbish long LCD inverter boards or the tv Tuner signal board for the replacement.
Mar 02, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Recording on a STB and being able to watch a DIFF channel.
It is possible to record a channel and watch a second channel. If your cable vision has digital-only signals, you will need a Digital tuner or a second cable box.
If your cable has conventional channels still, you can buy a splitter and run the cablevision to the TV and the CableBox at the same time.
Switch to the TV tuner, you see cable.
Switch to the recorder (connected to the CableBox) and you see what you can record.
Mar 28, 2010 | Televison & Video
Lost my motherboard CD
you can download your driver from here.
Select Product - Motherboard
Select Series - Socket A(462)
Select Model - A7M266-D
Click Search and a Page will come up asking Select OS.
http://support.asus.com/download/download.aspx?SLanguage=en-us
May 12, 2009 | ASUS AMD 760 MP Chipset A7M266-D...
Boot Failure
Try another stick of memory, I know that sounds funny, but I beat my head trying to figure the same issue out one day... and that was the issue....
Hope this helps, if so please rate my solution accrodingly. Thanks, David
Mar 19, 2009 | ASUS A7M266-D (A7M266-D/LAN) Motherboard
Windows Instalation
change the windows version
or change the ram
Nov 08, 2007 | ASUS AMD 760 MP Chipset A7M266-D...
Remote died while tv was on Video 2
Why, it is very easy. Just go to Menu manually (as u already did) and select 'Input'. Th eOptions Video1, Video2 and Tuner will scroll up one by one. Just select Tuner
Aug 19, 2006 | Sanyo DS27800 27" TV
Computers & Internet Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
