Rheem 81VP6S/430126 Water Heater Logo
Posted on Jul 14, 2011
After water is sufficiently heated up, water flow out of the overflow pipe for about 2-3 minutes. Is it normal?
A
Anonymous
No.
Water should not leak out of water heater.
Water should only come out of the TP valve and down the overflow pipe if water is too hot, or if TP valve is bad, or if you have stacking condition.
http://waterheatertimer.org/How-to-replace-TP-valve.html
http://waterheatertimer.org/Stacking.html
http://waterheatertimer.org/Leaking-water-heater.html
2answers
How do I stop hot water coming out of the overflow pipe. For a week the heater was off. Upon turning the water heater on and after the water was heated it began to run out of the overflow pipe.
Without knowing the make and model of the water heater, the overflow pipe would be assumed to be a pressure relief valve. There should be no water coming out of this unless the pressure in the system is too high, the valve is bad or it has been activated and wont seal.
I have a 40 gallon water heater that runs out after about 15 minutes.
Deepens how old it is could scaled up inside or the pipe in side which allows the cold water to flow to the bottom of the tank has worn away thus getting mixing at top of tank hence lack of hot water . may need to replace cold water inlet feed pipe in tank.
I have a Westinghouse WGRTNG199 tankless water heater. It will stop heating water and show code 42 on the screen when someone uses one specific shower in my house. This is the closest bathroom to the...
There is an outstanding chance that the shower causing the problem has a required flow restrictor installed in it. If you take the shower head off and look in the connection are you should see a colored screen or similar plastic piece. Take it out. The water heater has to have a flow of at least 1/2 gallon per minute.
Hi my baxi 105he dhw has stopped heating the water flow rate is ok,when i try ch the temp led,s rapidly rise up to 80 degrees then the boiler shuts down
Indicates low water flow. possibly bad electrical connection to flow detector in dhw pipe or seized dector in pipe or blocked up heat exchanger. certainly a blockage somewhere in the pipes
What is the gray gravely discharge coming from my PowerStar AE125 when using the hot water? It plugs up the faucet and shower heads within minutes and almost completely blocks the water flow.
Heating water can peculate chemicals out of water, such as metals and organics.
Especially above 138 degrees.
Have well water tested.
Turn down thermostat temperature.
Or reasonably harmless well-water bacteria can react with anode rod, or other reaction in softener, to produce colored water, and smells.
Different water can produce different sludges, brown, red, gray, black, yellow.
The sludge can also combine with deteriorating pipe flakes to clog water flow.
Sludge can accumulate over years in low spots in pipes, or at elbows and constrictions.
Have plumber flush pipes.
Or run new pipes.
Also delime tankless yearly, and flush with white vinegar as shown in product manual, and treat bacteria with H2O2 hydrogen peroxide.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
Overflow pipe flowing
Check temperature off the water for proper functioning thermostat. Look at set points on heater's thermostat. It's made to let water out when water get's to a certain high temp. More than likely it will be the pressure relief valve going bad and not holding.
T&P releif valve can be replaced on heater. Turn water off and remove with a pipe wrench. It will come out and any hardware store will carry it. T & P pressure relief valve is 3/4 threads.
When installing new one use teflon tape on threads.
1helpful
Worcester 350 boiler pressure low - warning light comes on so i top it up with water half an hour later the pressure drops again. Have checked rads and pipes no obvious leaks. Water seems to be coming out...
That overflow is the Pressure Relief Valve.usually they are set at 3-3.5 bar but over time they can be gunged up inside and leak/allow water to flow out. Dismantle & clean or replace. Turn off mains water and ch pipes before removing - operate valve remove & allow for some water to leak from it
4helpful
2answers
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
