Question about RCA CC-432 Camcorder
Spots on my display
I'm seeing bright crystal-shaped or colored spots on my viewfinder or on the LCD monitor of my camcorder.
    Master:
  • 473 Answers
There's nothing wrong with your camcorder. Cystal-shaped spots, black spots, and bright spots of light (red, green, or blue) can appear on the LCD monitor for a variety of reasons. These spots are not being recorded on your tape. But if these are distracting your videotaping, consider taking a slightly different shooting angle and the spots should go away.
Posted on Sep 06, 2005
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Growing Black Spots on Insignia LCD Flat Screen
Black dots/spots on an LCD panel display indicates either a dead pixel or a stuck pixel. Alternately, if you press lightly on the black spots and they go bigger/darker, then in some instances, it could be that the frame holding the display has been slightly warped when too strong a pressure was applied when it was being cleaned. Should this be the case then corrective measure would be to disassemble and flatten whatever area was dented. Some have reported success with the use of a suction cup. Perhaps this, this or this might be interest you.
If the unit is still under warranty, please try discussing your concern with your dealer. Though a few small spots are an acceptable norm. Alternately and if the warranty has lapsed, there are companies online that offer LCD replacement kits or will replace/fix your LCD and it would cost you less than the cost of a new screen or TV.
Other than the above, am afraid that your options are rather limited.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Insignia IS 20" TV040919 TV
In a span of 3 years my Samsung LCD Monitor (SyncMaster740N) started Having Black Spot all over the Screen, Starting from the Corners and Now it Blinks after every 10 Seconds, The buttons for Color and...
Fistly the black dots that are appearing are called "Dead Pixels". They cannot be removed as they are liquid crystals that have stopped working. When you purchased the LCD it should have come with a support CD. On this disk it should have a program to manually set the brightness on your monitor by using your mouse.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | Computers & Internet
Black spots on the screen
I think you should try going to the store and checking if your monitor is still under warrenty. From the description, I think it is beyond repair.
Jun 26, 2009 | Samsung Computers & Internet
Bad colors on Swivel LCD Display
it is more than likely the flex in the hinge for the lcd. the hinge might need changing. suggest the camera be taken to a qualified panasonic tech.
May 31, 2008 | Panasonic PV-DV103 Mini DV Digital...
Dark discoloration around x2gen monitor
Dark spots indicator that the Liquid crystals are not being dispursed properly when the monitor is powered on! That could be a problem! In additon it depends on how old the monitor is as well or how new because nothing is guaranteed! Monitor is going bad!
Nov 26, 2007 | X2Gen MG19MY 19" LCD Monitor
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
LCD monitor and electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
LCD Monitor on and the electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
RCA CC-432 Camcorder Logo
221 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
