Question about Intel DG31PR Motherboard
No video signal
Made all necessary conection but after conect the monitor stil nothin appear on screan.The motherboard is new and i use it with a Intel Core 2 duo E7200 processor and with 2 slot of DDR2 -2G each one. Can you help me?
    Brigadier General:
  • 5,158 Answers
Always start with the merely obvious. Make sure all connectors are plugged in. make sure the monitor is on. Are you using more then one video card or just the onboard video. If you have another video card as an add on, hook up the monitor to that one (shut down the computer before you change connections)
Robert
Posted on Aug 27, 2008
No signal going sleep
how old is your monitor? can you try to conect another monitor your pc has integrated videocard? does it turn on and beeps?, you should check the back pannel of your pc and try to conect it to onboard video first (if it has), if you get signal get into the bios and change video output from onboard to a external card. if this thing dont work, then vga cord may be damaged or the card is not installed right or not working.
Jun 05, 2013 | Fujitsu Siemens Computers & Internet
Starts up put in drive wont go anywhere put in reverse nothin
I suppose ur car is AT, make sure u have enough oil in the gearbox, it is not engaging. Are the drive shafts stil conected to the gearbox? Check them out, good luck.
Jun 26, 2011 | Hyundai Sonata Cars & Trucks
How do I connect my Toshiba LCD television to my computer using hdmi
HDMI carries both "audio" and "video" signals, while DVI carries only "video" signals.
Does your computer have a HDMI-output port, or separate DVI-video and stereo-audio ports?
If the former, then one HMDI-to-HDMI cable will make all the necessary conections.
If the latter, you'll need a cable to connect "line-out" from your computer's sound-card to the left/right RCA-jacks stereo-inputs, and you'll need a DVI-to-DVI cable to transmit the "video" signals.
Oct 22, 2010 | Toshiba Computers & Internet
When monito turned on itsay no signal all
Something is loose. Either on the video card or the monitor. Either that or the video card is broken. This would not happen for any other reason
Sep 08, 2009 | AOC Computers & Internet
No monitor signal
have you tried checking the monitor to another computer? it could be the monitor?
if not, could be the graphics/video card, or even the motherboard itself could be faulty!
Jun 19, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
EN9250 worked graet 20 minutes ago. Unpluged it to move computer- Plugged it right back in and now no signal. I have checked all connections and still no signal
Make sure the cable is plugged into the video in. Shut down the computer and unplug it. Unplug you monitor again and also check conections by removing the cable make sure no pins are bent on the monitor or the conection to the computer. Plug all back in. Turn the monitor on first and then the computer. I hope this helps. If not let me know I will need so more info. Good Luck.
Jan 15, 2009 | Computers & Internet
COMPUTER WON'T BOOT UP
The possible reason why there's no signal on the mobo are, first of all it can be a problem with the video card and since you already tried replacing the video card and still no sigal so it means not the video card problem, you can also try to connect a different monitor if possible to check if its not a problem with the monitor and also a bad motherboard will cause this since the video card is connected to it and so if you already try a different monitor and still the same problem motherboard is the one that is bad....
Nov 02, 2008 | Abit IS7-V Motherboard
Dancing red pixels
Your Video Card´s DVI output is probably damaged. You will have to replace your video card , or use only the VGA output.
Aug 18, 2008 | Computers & Internet
Monitor problem
Sounds like your video card is failing. If you get video directly from the motherboard then you may need to replace it.
May 09, 2017 | HP Pavilion MX90 19" CRT Monitor
Motherboard
check cable pins they may be bend and make sure there is no bad conections or short circuit on the motherboard to the chasis to do a diferent test use a pci video card and plug the monitor into it
Dec 31, 2007 | Intel D845GVSR Motherboard
Intel DG31PR Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
