Question about ASUS K8U-X Motherboard
    Brigadier General:
  • 5,158 Answers
Define over voltage. If you have the skill level to do it, go into the bios and check the voltages. Have you been trying to overclock the cpu by chance. Also have a look at the capacitors on the board. are the tops rounded ?
Posted on Aug 27, 2008
In asus P5GL-MX mother board the power supply regulator ic 2 piece has been damaged (short) how would i know plz help me
Hi if the regulator ic has been damaged in your power supply even you replace that there are some electronic component where also damage because the ic will not damage where there is no over voltage flow on it. This means there are some resistor or a transistor is also shorted it advisable to replace a new one than to repair your power supply. Because even you repaired it the performance and the life span of your power supply is not stable. So it better to replace a new one.
Jul 14, 2011 | ASUS P5GL-MX Motherboard
Asus P5 GC-MX Board proccessor does not get power what parts should be changed
First, check if the connection from the power supply to the motherboard is properly inserted. If it's loose, that may be whats causing you to receive no power from the supply. Check the wall socket to make sure it works, as well as checking if everything is plugged in properly. If you are still getting no power, then it maybe time to buy a new power supply. If there is some indicator of power to the mother board , such as an LED or light that turns on when plugged in, there may be a problem with your power switch.
Mar 29, 2011 | ASUS P4PE-X Motherboard
New power supply does not it the motherboard
well there are two ways to to figure out which item is broken first you can hook up the power supply and test the pins in the plug with a voltage tester to see if it has power. I do not recommend this approach if you are unsure of what you are doing the voltage coming from a computer power supply is very dangerous. the second thing you could do is attach a different power supply to *********** board if ti works the mother board is good and it your power supply that is busted. Also make sure to check the back of the power supply and make sure it is set to 110 and 220 voltage because this can cause your power supply to not function correctly. It will be a little red switch on the back that says 110v on one side of it and 220v on the other.
I hope this helped.
Thank you,
Jul 03, 2010 | EliteGroup L7VMM2 Motherboard
I have a problem with sata driver on motherboard asus k8u-x. please giveme sata raid
u can try the web makers site to update the bios or it might be a bad board
May 08, 2010 | ASUS K8U-X Motherboard
Asus K8U-X motherboard,which ram memory , and processor support?
hi..for this mother board model asus K8U-X only same brand Processor u can oly use.Like if u use Sempron made by AMD only AMD Processor for that board.Memory support is DDR1 PC400 1gig up to 2gig...good luck and Have a Nice Day..
Jun 14, 2009 | ASUS K8U-X Motherboard
P35-153-11z9 mother board need network adapter driver ?
Hi Paul, there isn't a separate driver for the Realtek 8201CL 10/100 Mbps Ethernet Controller. The driver is part of the chipset software & should have been installed when you installed the Asus motherboard support CD software. (Asus K8U-X).
Double check your bios settings. Check that the onboard LAN controller is set to Enabled. See page 2-19 in your Asus manual.
Link to Asus;
Link for manual;
Realtek wants people to use Driver Detective to help in finding drivers from RealTek, see the link posted;
(I do not know what the these mean from your post, P35-153-11z9)
If your LAN is set to enabled in the bios, try reinstalling your Asus CD software, (Chipset drivers). If the drivers still fail to install it is possible the LAN controller is defective.
Thanks for using FixYa Paul!
Need more help? Post here.
Mar 14, 2009 | ASUS K8U-X Motherboard
I cant find the right sound device for my asus k8u-x mother board
Download and install the driver scanner and all your driver issues will be resolved as it will scan and download the latest drivers itself when you run it.
Click here to download
or go to:
You will be required to extract the file using seven zip.
or go to
Feb 02, 2009 | ASUS K8U-X Motherboard
IBM Mother board mlack out
just buy another power supply with a higher power for the problem is not on your computer but on the power supply,then try to plug it in a 220v voltage regulator,but i surely recommend that you'll buy a new power supply ok
Apr 08, 2008 | IBM 486DX 80486 (32G4144) Processor Board
ASUS K8U-X Motherboard Logo
175 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
