Suspension & Steering for Ford F150 Flareside SuperCab Logo
Posted on Jul 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F150 flare side front end shakes is aligned, new tires, new rims, new bushings, new drive line 3" rear lowering kit
Anonymous
Level 3:
President:
  • Master 228 Answers
  • Posted on Jul 14, 2011
Anonymous
Master
Level 3:
President:
Answers
228
Questions
0
Helped
132887
Points
5507
The front under carriage has what is called a main drag link, it ties from one wheel
spindle to the other, the way to check it is to grab it with both hands if you can move
it and has lots of play, this is your problem. but if you did modifications to your truck,
you may have to purchase a modified version to correct the changes made to your
truck. if worn out can be replaced, but because of modifications you may have to go
with one that fits your truck . good luck!
Timothy Crawford
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 26, 2013
Timothy Crawford
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
353
Points
Start by checking for loose front end parts. If the problem started after all the work was done I would suspect a tire or wheel problem. Try swapping another set of tires and wheels on the vehicle and see if the problem goes away.
Anonymous
Level 3:
Brigadier General:
  • Master 3,301 Answers
  • Posted on Jul 15, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3301
Questions
0
Helped
1013010
Points
10058
Or you could have simply thrown a tire weight, It happens all the time, have the tire balance checked
Front end constant wobble 2008 kia sportage. I have replaced tires, rims, struts and had 4 alignments. I'm at 80,000 miles and it has gotten much worse. Pulls hard to one side.
Could be control arm bushings
Sway bar links
Wheel bearing
Ball joints
Rack and pinion
Lift car and shake the tire from side to side, then top to bottom. Any play or wobble means parts are worn and need to be replaced
Why does my the rear end of my car shake at highway speeds?
have the rear suspension bushes checked out including the shockies.
I would also suggest a rear end wheel alignment and a wheel bearing check
3answers
Vibration in front end while driving. steering wheel shaking. stops at higher speeds.
Have your tires checked for tread separation and your wheels checked for balance. Out of balance tires will go through harmonics such that at one speed it will vibrate a lot more than at another (higher or lower) speed.
Shaking and Front passenger tire keeps wearing
damaged the lower control arm of the suspension
the shop doing the wheel alignment is clueless as it is not possible to get the alignment figures with any damage and they should have given you a report to that effect
Take the car to an accredited front end specialist shop for a check of control arms , bent strut and have an alignment done on the rear first then the front
claim any excessive cost on insurance
When driving down highway my front end has shimmy i have new tires new rims ,struts,tie rod outter ends,new sway bar bushings and my wheel bearings seem fine what is causing the shake
did you get it aligned !! if not, that may be why. good-day !! if you let go of steering wheel while going straight and it vears either way it means its out of alignment.
4answers
I have a 2000 Volkswagen Beetle that is shaking while driving. It usually shakes when I reach up 55 or 60. I do have a hole on the muffler just before the catalytic converter. "I think". Not sure...
This is most likely an alignment a tire issue. The first thing to check is your tires. Make sure there aren't any foreign objects stuck in the tire tread. If you don't visually see anything take it to mechanic that can balance your tires and check your alignment.
2answers
Front driver side wheel shakes wile driving 60 mph and or lower
Sounds like the tire is starting to delaminate. How old are the tires? If you take the wheel off the car, you may be able to see a bulge in the tread. What is happening is the thread is starting to come loose from the steel belts underneath. It can happen to any tire with age. It's a serious problem: eventually the tread will separate completely, while you're driving, and throw the tread all over the place, most likely damaging your car. It could even cause you to lose control, or it could hit someone else, whatever. Gotta replace it, and soon.
If it's just the one wheel, not a shimmy in the whole car, I'd say the tire is going bad. It could also be a loose/worn out balljoint: with the front wheel(s) off the ground, try to move/shake each wheel. If there is any 'slop' in the wheel, you have a bad balljoint. Which requires professional repair, if only for a new alignment once the work is done.
Good Luck!
chris
3answers
The stering
I would check your front tires for any defects if there is none noticeable I would get a front end alignment. Most of the time you can tell if you need a alignment if your car pulls to either the right or left while driving. Hope this helps.
3answers
Vibration at 70mph after new tires and alignment and much trouble shooting
it could be as easy as checking to see if you have a dented rim.....
or as expensive as changing the "constant velocity joints" but only if it is a front wheel driven car.....
how are your shocks?
have they repacked the rear bearings..."but only if not rear wheel driven car"
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
