Question about RCA CC-432 Camcorder
Stuck in Play-Pause mode.
My camcorder is stuck in Play-Pause mode.
    Master:
  • 473 Answers
Simply press REC/PAUSE to return to normal Playback mode.
Posted on Sep 06, 2005
SOURCE:
HELLO, MY CANNON ZR 100 IS STUCK IN PAUSE MODE
This is most likely due to a failed Pause / Play switch and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Apr 06, 2011 | Canon ZR100 Mini DV Digital Camcorder
Sansa Clip 8GB is stuck in pause mode
You mean it hangs up at pause mode and you can't turn off you device? if so, push up/press power button and hold for 10 to 20 seconds until the device turn off.
Then, turn on. if it' working. You should update new firmware.
Good luck
Jan 17, 2010 | SanDisk Sansa Clip MP3 Player
Sansa MP3 player stuck in pause mode
take apart and clean the contacts on the buttons
Aug 06, 2009 | Audio Players & Recorders
Stuck in "pause" mode
Hold the red button down for a couple of seconds on the right side of the camcorder.  Does the pause go away?
Sep 09, 2008 | Canon ZR40 Mini DV Digital Camcorder
Canon zr40 stuck in pause mode
Remove the battery.   Wait 10 seconds.  Put it back in and see if that resets it.
Video transfer
You can stop and start as much as you want. Then you just hit play and record it onto your pc with the software. There is software you can get that will know when you start and stopped and will break your video up into scenes automatically onto the computer.
Hope that helped,
Lee
Jun 07, 2008 | Pinnacle Video Transfer
Hard disk prob
hard disk is bad.
can you format?
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs Zen Touch MP3 Player
Cannot playback minidv in VTR mode with pd100
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 28, 2007 | Sony Dvcam DSR-PD100 Camcorder
Stuck in "Record Mode."
Take it back to the dealer while you can! Either let them show you how to prevent this or give you a new one.
Jul 06, 2007 | Canon ZR850 Mini DV Digital Camcorder
RCA CC-432 Camcorder Logo
112 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
